hi guys, this is my r33. Quick rundown. 93 series 1. heavy duty clutch, 3.5 exhuast, pacemaker dump front pipe, 20inch wheels ( 10 inch wide in rear, 9's in front) gold highlights in paint, front mount, cai, boost controller......ect
just returned from a week at the work shop, wider rear quarters, new window seals, all resprayed, now has re-map computer, hks 25/40. just had full service also.
Edited by tonga
https://www.sau.com.au/forums/topic/178541-my-r33-gtst/
Your car with huge 20" wheels doesn't look too bad. :laugh: Usually car's with 20"+ wheels either look gay or look good in my opinion. Yours looks good. :)
I agree generally cars with 20" wheels look too over the top but they look awesome on your car. Hows the drivability with those wheels though?
https://www.sau.com.au/forums/topic/178541-my-r33-gtst/#findComment-3256540
yer mate, it took a bit to get them to WORK so to speak. lipping and some negative camber... but soon guards are getting flared so we can drop it a little lower... but all in all it was worth the effort. thanks for your comments
https://www.sau.com.au/forums/topic/178541-my-r33-gtst/#findComment-3256558
Looks really nice mate. I agree with the above comments regarding the 20's. Usually they look kinda wak, but you have got a nice set the suit the car well. :yes:
Now you just need to get some black number plates and the better perferated 'p' plates :blink:
https://www.sau.com.au/forums/topic/178541-my-r33-gtst/#findComment-3256925
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
