Ok just got a quick question that i want answering because i have asked a few ppl and no one knows what the hell this thing is for. Im pretty sure it's not really important and at first i didn't really care. However my curiousity is starting to get to me and i want to know what this is! :laugh:
So lets play GUESS THIS PART!
What the hell is this thing in the HKS GT-RS kit?? I fitted the whole kit and it runs beautifully, but this part wasn't used and no where in the jap instructions does it say what it's for. So any one know or care to take a guess? I was thinking some sort of heat shield thing?
https://www.sau.com.au/forums/topic/178582-name-this-part/
Ok just got a quick question that i want answering because i have asked a few ppl and no one knows what the hell this thing is for. Im pretty sure it's not really important and at first i didn't really care. However my curiousity is starting to get to me and i want to know what this is! :yes:
Hmm that a nice looking turbo :D :D
What power is your cra making now? Power fc?
What the complete kit set you back for?
Sorry i have no idea what that part is..... :blink:
https://www.sau.com.au/forums/topic/178582-name-this-part/#findComment-3256865
Pretty sure its the heat shield that goes over the orange silicon hose.
Search for a kit installed and you should see what i mean.
ahhhh!! That actually sounds correct, looks to be the same size as the hose aswell. I think you are right, hahaha what a stupid part :yes:
Thanks man, my curiousity is gone now :blink:
https://www.sau.com.au/forums/topic/178582-name-this-part/#findComment-3256977
Sorry i have no idea what that part is..... :yes:
Thanks man, it looks sexy as in the car. Here's a pic of it all installed. I got the kit off of nengun and it was around $2500 delivered, so a very good price in my books.
I'm still running it on the stock ECU (I know, i know i need a ECU!), but it runs ok on it. Comes on boost really early and pulls hard, sounds absolutely unreal! Really loud spool/whistle sound, i love it! But yeah i wanna get a power FC for it soonish if i can get my hands on one, then the fun will begin :blink:
https://www.sau.com.au/forums/topic/178582-name-this-part/#findComment-3257002
Thats a great price well done :yes:
Have you had the car dyno'd since putting it on?
You still sunning standard injectors and afm?
:D
https://www.sau.com.au/forums/topic/178582-name-this-part/#findComment-3257172
Stock injectors and AFM at the moment. I havnt had the car dynoed since the new turbo so ur guess is as good as mine to what it would make. Ill probably get a SAFC for now and see how far i can push that. The next performance step is to go a Power FC and injectors but like with most mods, money is holding me back for the time being.
https://www.sau.com.au/forums/topic/178582-name-this-part/#findComment-3257218
Yeh i know what you mean!
Ive got around 200rwkw but am considering a turbo upgrade, but its all the stuff that has to go with it that is holding me back - pfc, injectors, afm, clutch - it all adds up so quickly!
https://www.sau.com.au/forums/topic/178582-name-this-part/#findComment-3257273
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
