hey guys,
i have a few things for sale (all brand new), from an unfinished project.
1.Brand new original Garrett GT35/40 with .70 compressor and 1.06 exhaust housing rated at 700hp.included are braided water and oil lines.
Asking $1900 ono.
2.Brand new Turbosmart 48mm Progate.
Asking $800 ono.
3.Brand new custom made Stainless steel manifold to suit the turbo and wastegate, bolt onto rb25 motor.
Asking $700 ono.
4. RB25de head, non vct approx 25,000km when it was pulled out, currently pulled apart was going to get it serviced and worked but decided not to go through with it. it is missing intake manifold, throttle body, injectors, fuel rail. comes with wiring harness and 5 coils, 1 broke when it was taken out.
Asking $500 ono.
5. Series 11 RB30 bottom end, came out of an N/A VL unsure of the K's as it had been removed when i got it, all though everything on it seems to be in good condition.
Asking $70 ono.
All Reasonable offers will be considered on all items, just want it all gone.
inspections are welcome for serious buyers,
items are located in SYDNEY.
any questions contact me on 0403 557 874
https://www.sau.com.au/forums/topic/178594-fs-brand-new-gt3540-turbo/
  • 3 weeks later...
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
