Drift King drives both the Amuse Supra and Mines R34 GTR. this is an oldie, but a goodie.... i love the comments they make right at the end. "Accelerate's as fast as the GT500 cars...". just awesome....
http://www.youtube.com/watch?v=f8yy65oIths
  • Replies 168
Prank call the telemarketer...
http://www.youtube.com/watch?v=J5z4Vs26-TI
I usually just tell them that "now isn't a good time for me" and ask them for their home number so I can call them backat a time thats convenient... and when they say "I can't give you my home number, thats private" to which I respond with "WELL THEN WTF MAKES YOU THINK MINE ISN'T????"
They don't like that much :D
Edited by LadyBytes
I am sorry but this takes the cake for just out right AWwwwwwwwww factor he did pull off a sweet 720 but just watch what happens then.
JAKE BROWN + X GAMES + BIG RAMP = AWWWWWWWWwwwwwwwwwwwwwww
and another view with more comments AWwwwwww
http://www.youtube.com/watch?v=sOKhe9k4eg4
Dont know how to describe this one other than a Swedish boy deliberately jumps into a wall in the most hilarious possible position (bar a nut shot), just keep looping the body slam, gets funnier every time
http://my.break.com/media/view.aspx?ContentID=350207
haha!
changing the theme completly now...! i love this commercial. i wish we got it here.... turn up the volume and enjoy!
http://www.youtube.com/watch?v=7qT_q8PXFrw
the bridge at the 50 second mark is Sea Cliff bridge down at Stanwell
Smack in the middle of the city of Munich is a permanent wave that people surf on all year round
Once you are there you will see better surfing ones for the same place, but this vid gives you an idea of what we mean by "smack in the middle of Munich"
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
