ok, seem ppl are putting up pics of there stereo install....so mite as well do the same!!! :yes:
CAR: HR31 GTS coupe
CURRENT GEAR: 1 new cheap pioneer head unit with 2 front 6' single's....clear but certainly not doof...
FUTURE GEAR: see pics!!
OTHER: standard interior, very clean, ditto with boot. almost stock RB20det...tidy car, clean all over..nothing much more than standard..
twin 12" subs will have a custom enclosure to go in boot along with some LED's etc...just to spice up the usually boring boot area!!
more pics as the install happens!..check back now.. y'hear!! :blink:
https://www.sau.com.au/forums/topic/178603-dodgsuns-doof/
ok, BIG stuff happening. spent the weekend stripping the interior and fitting the gear.boot has been redone with grey fabric and rear parcel shelf re-done in black fabric to contrast with the grey/silver, and also with MDF cut to fit (with cut-outs for the rear wiper). head unit in and now centered (standard was off to the left (?), plus doors done...pics to follow when image shack works!!
edit: stuff it...went to photobucket instead! HA!.
Remember...this is a limited money project...i could use vinyl, or something more bling worthy...plus lots of LED's etc...but this is to show what ANY one can do on a tight budget. (well kinda tight). AND this is stage 1..just get it in and working.........later down the track the boot will be upgraded to something more show worthy!!
Edited by dodgsun
https://www.sau.com.au/forums/topic/178603-dodgsuns-doof/#findComment-3276957
old speakers.................................................................rear shelf
left one is "adjusted", right is original.. .................... empty back seat thru to boot..
of course the first thing i did!!..................................... left is new, right is old.
and i'll lose my spare tyre too.. oh well!!
https://www.sau.com.au/forums/topic/178603-dodgsuns-doof/#findComment-3277053
looks good mate. just a word of caution tho, with yoru sub boxes there, make sure they are secured very tightly to the floor and kept off the rear quarter skin. as a fellow 31 owner, i have seen, and been the victim of objects being pushed against the panel from the inside and pushing dents out when going round corners. its a nasty result.
otherwise, good work! i'm currently working on my own boot setup. where did you get your carpet?? i just bought 60 bucks of auto carpet but they only had a dark grey colour - would have preferred light grey....but oh well.
https://www.sau.com.au/forums/topic/178603-dodgsuns-doof/#findComment-3292604
haha..yes sub box's not secured yet.so i know what you mean...bangbangbash etc... will be done when mate can get car in!.....and there will be a fill panel from the subs to the rear of seat so as to cover up the wheel well, make it all look like a continuous panel.
oh the grey carpet ?? my mate works for Straithfield audio and this is what they have in there install section...nice of him to use it for moi! eh!
AND i also got a 2farad cap in aswell...but didnt take a pic yet..also got LED's and some strobe lights coming soon (HK) so when it's all in i'll get some more pics and maybe even a vid (youtube) of it all working!!
Edited by dodgsun
https://www.sau.com.au/forums/topic/178603-dodgsuns-doof/#findComment-3296702
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
