how about a t4 60-1 im running a rb26 in my s14 for drift and looking for a single turbo setup for response too!
i was leaning toward a t4 60-1 but i saw a post n the t3/t4 isn't that a little small? i dont want too small of a turbo! i need the massive response but wont too small just suffiate the motor on higher rpm? specs like t3/t4 compressor- ar.50 turbine-ar.63
that should get massive response but what about top end!???
how was that response as a moderator uncalled for?
so because im a moderator i cant have an idea or view on something?
i was just thinking out aloud, there a more than one way to skin a cat and drifting that ive seen requires lots of wheelspin
so one way to induce wheelspin is power, but there are other ways to get wheelspin, suspension, tyres, diff setup etc
and i dont get the cool off comments? it was a suggestion/idea relax....
i dont have a problem with drifting and my response was a serious one
i think you have the common misconception that drift is nothing more then a controlled powerslide around a corner.. maybe once upon a time in aust it was but these days it requires some decent suspension and tyres to get the most grip possible, Some of the cornering speeds carried while drifting these days is pretty bloody fast.
back to the original question... im pretty happy with the power my car has, i just want a reliable package, so that means no turbo wheels falling off. Im not after big rwkw figures as this further pushes every single componant further away from the reliable margin...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
