DD confirmation, what constitutes that? I've already payed, do I just need to take a screenshot and print it out to prove it?
Yep, just do that - Will be fine.
If it doesn't come up on our bank transaction, I will chase you.
  • Replies 223
form download.... check
form printed.... check
damn where is my CAMS licence number.....check (found it)
damn that fax machine meltdown heaven....redialling.....come on........damn my machine....... ahhhh ......check
transfering money.......damn HSBC.....damn slow internet..... damn firefox.....damn damn......IE FTW.... check
does it look like i want to do DECA :-)
Please please tell me I made in there.....just. Lol i so want to do my first deca now that I am back in Victoria!!
What a nightmare trying to get forms in lol, internet here is shagged, run 2 doors down and manage to get on after chasing my login details, running to get my membership card, and then redialling on the fax machine.
If i don't get in I am going to have to drown my sorrows with bourbon tonight >_<
Current Entry List
1 Justine Schuller R32 GTST
2 Adam Newton R32 GTST
3 John Andrews R33 GTR
4 Scott Andrews R33 GTST
5 Chris Thomson R33 GTR
6 Andrew Richmond R34 GTR
7 Nathan Lawrence R33 GTR
8 Russell Cunningham R32 GTST
9 Michael Dessman R33 GTST
10 Jarrod Moore R32 GTST
11 Evan Boyack WRX
12 Gareth Evans R32 GTR
13 Scott Bailey TX5
14 Tony Buckland WRX Sti
15 Troy Brisby R32 GTST
16 Simon Balog R33 GTST
17 Matt Phillips Bananna
18 Steven Zozula 200SX
19 David Mocnay 350Z Track
20 Stephen Hugh-Smith (N1GTR) Supra RZ
21 Ando (A31Deviat)
22 Nicholas Smyrnios (INTUNE) GTR
23 Victor (d00dz)
24 Chris (evil weevil)
25 Shawn (Smoky)
26 Jessica (Sinful)
27 Andrew (nuttshunglow)
28 Anna (msnismo)
29 Liz (Liz)
30 Brad (Risking)
31 Timothy Andriesen (tjandriesen) R33 GTR
32 Sam (SAM916)
33 Jen (Tripin)
34 Wayne (DJ Brave)
35 Peter Blythe R34 GTT
36 Adam Nightingale R34 GTT
37 Aaron Tan 200SX
38 Michael Catena R33
39 Joel Strickland Mazda3 SP23
40 Martin Sullivan Bluebird
41 Share Creed 180SX
42 Muhammad Ziad EVO 8MR
43 Michael Pope R32 GTR
44 Tim Cottam EVO 9
45 Ryan Bell Sil80
46 Tom Giordano R32 GTST
Reserves
1.
2.
3.
4.
5.
Update the reserves before i go insane
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
