Hi all,
I need to sell my daily driver, got to many cars apparently, and a few bills to pay. Really not keen to sell after a long road getting the car to a really reliable state.
It has just passed Dickson RTA (but with raised springs).
alot of work done getting it to be a fully road worthy vehicle
new gear box, new tail shaft, new bushes, new brakes, new computer, new filters and lubracants, new leads plugs and ignition system, new white walls, new horn, chassis strengthening for steering box.
I have just put all the scroll work on and the car turns alot of heads. This is a really good car for the money, I mean think of what else you can buy for this much with so much ol skool appeal?
I am after $2000 for the car.
Contact me on 0418 327 427
https://www.sau.com.au/forums/topic/178699-ol-skool-merc/
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
