Start date: 1st August, end date 31st August.
Item: R32 Nissan Skyline ECU upgrade for BP ultimate.
Price: $150 per kit including delivery.
1: bubba - confirmed
2: CeJay - confirmed
3: johnnilicte - confirmed
4:
5:
6:
7:
8:
9:
10:
11:
12:
13:
14:
15:
$10 from every kit sold will be donated to SAU. group buy will close when 15 units are sold or the 31st of August arrives.
After a year of developing and tuning I have finally finished something I think will be of great benefit to the SAU community. especially now the power FC is difficult to get for the RB20det. The tune I have developed is for these who have completed what most consider to be the standard modifications for an R32 skyline. I have spent in total 16 hours dyno time over 12 months and tuned over a dozen cars to get a result that will optimize the performance of an R32 skyline.
The tune is designed to be used on R32 Skylines with the following upgrades:
RB25 turbo
high flowing split dump pipe
3" exhaust
FMIC
Hiflow 3" cat
upgraded fuel pump
While every engine differs especially once it is modified this tune is designed to maintain 12:1 AFR's with the modifications listed and will dramatically increase your response and midrange power. The tune also has increased the factory mass airflow cut beyond the point that an RB25 turbo can supply (around 14psi) so there is still a safety margin in case boost is wound up too high or your actuator hose is split. I have also removed the speed limit and set the rev limit to 7300rpm for engine longevity.
Please note this is NOT a replacement for a customized tune that has been done by a tuning professional and is not a one size fits all tune... If you want a custom tune please do a search for Dr Drift or Speedlab.
The kit is also supplied with valet mode and has been developed for those times you have to leave your car with a mechanic or anyone you are weary leaving a 200rwkw car with. By simply pressing a button you arm valet mode. Your rev limit is reset to 3500rpm. The car CAN NOT rev over this while it is in valet mode. This reduces the cars top speed to approx 117kmph. Valet mode also reduces the car’s power output below the 3500rpm rev limit making the car feel sluggish and uninspiring to drive, thus further reducing the chance of someone thrashing your pride and joy. Once you are back in possession of the car you simply disarm valet mode and you are back to normal high performance mode.
the kit is simply fitted to your existing ECU and comprises of a new chip, pcb, cover wiring, switch a socket. you will have to have your standard rom removed from the ecu and have the provided socket fitted in its place. this will need to be done by an electronics repair shop and should cost less than $50 Full instructions will be provided with the kit.
The dyno run below was an R32 gtst with RB25neo turbo, FMIC 3" exhaust, bosch040, cheap hiflow cat and no other modifications. the numbers hand written are to reference the same car with the turbo that was fitted later. and do not reflect on this tune so ignore them
The dyno run below is my personal car and has the following modifications. sliding preformance turbo, GTR injectors, GTR fuelpump, FMIC, 3" exhaust with metalcat and splitfire coils. this dyno run was done on low boost 16psi. hence the rich AFR. full boost of 19psi yeilds 240rwkw and perfect 12:1 afr's this tune is also available with the kit. please specify if this is the tune you require
If any more information is needed please PM or post below.
Thanks!
A lot of PM's and a lot of questions :rolleyes:
for all those that are interested but need to ecu modified PM me. i have a list of electronics shops that will fit it for you on the spot for a few $$$.
and yes $150 includes the remap for all these that have asked :thumbsup:
Can you elaborate on the included remap?
What would you like to know? the dyno sheet above for 204.2rwkw is from the remap with the modifications listed with 98 octane BP ultimate, speed limit is removed RPM limit is 7300rpm. AFR's are 12:1 response and power is improved timing is increased to produce more peak torque and power
pls let me know exactly what you want to know >_<
Oh no dramas, from the way you said ppl were asking about the remap I thought there was another one involved (something along the lines of have it dyno'd, send you the graph and you tweak slightly). I already got all of what you said the first time so sorry for making you repeat yourself >_<
Hi there,
Would these remaps have a provision for more than 14PSI? As I would like to get one for the time being and eventually purchase a high-flowed turbo from Slide... I'm not too keen in replacing the injectors so I do not plan to run more than 18PSI.
18 psi on the standard injectors with a hiflow from slide will be well and truly over what the injectors can supply. If you added a FPR you should be able to run that sort of boost with a slide hiflow. I can not guarantee it, but many have dune it with success.
How would the AFR look if I did run around 16~18PSI?
If this remap is capable of running more than 14PSI and maintain a decent AFR put me down for one.
CHeers,
Johnny
CHeers,
Johnny
14 to 16psi will be perfectly acceptable anything over that and you will need a FPR :P. I will put you down for one :(
^^ Likewise.. would like to get it installed in a spare ECU for when I take my car to the shop to have fuel pump fitted and power runs done..
very interesting...
we already have a jap remap for our s13 with rb20 and 25 snail and a safc2.
will test how this setup goes first but if its not that good i will definately be keen
You won't regret it guys.
Im running one of these remaps in my car
Boost comes on earlier, and harder
I've got heaps more midrange power and response
and made 182kw on 14psi
I think Australia Post have stuffed up again.......
they had my intake pipe sitting at my local post office for the past 2 days, and they said they dropped it off but no one was at home... what a load of BS because I've been home all week!
Hope my remap comes soon, or else Auspost will have a new brick through their window
Edited by johnnilicte
Be sure to attach a note stating their inadequacies..
I've been having a lot of packages arrive over the last couple of weeks but no remap in there ;) Nic has been very helpful though and hopefully Auspost pull their proverbial finger out!
Has anyone in this group buy received their remaps? I haven't yet.... starting to wonder if Auspost has sent my item to another house as per usual.
Received it today, cheers Nic. Trying to source a spare ecu to have this soldered into then I'll get it checked out on the dyno when I get my fuel pump installed, I'll let yas know how it goes :D
Guest
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
