Hey - got my SAFCII fitted & tuned today! Very happy with results. Mech. told me I should have used the Power FC instead - I said he shoulf pay me the two grand!!!
Anyway, I had a massive (read BIG) overfuelling problem on standard settings and the graph rose to about 90rwkw then dived at 4500ish rpm (falling below 70 rwkw) only to recover to 93ish at high revs. YUK!!! I knew that "boost was more than BANG...whimper...splutter!
So, at the same boost (10psi) it now looks (and feels!) the business with a smooth curve all the way to 6600ish rpm and 137rwkw. At 5500rpm it's now making 51 more KW! ! ! ! ! ! Money well spent it seems. What a relief!
The air-fuel ratios were previously dipping below 9.0:1 from 4500, and all the way to redline. With ratios now in the 13:1 to 11:1 range through the boost range, the engine can finally breathe!
Not bad for less than $800 altogether, including fitting and tuning!!!
The peak figure seems a little low compared to some of the guys on this forum, but I have tuned my previous car on three dynos, and the last was on this guys. My little NA VTEC produced 95+rwkw on two dynos, and then 77rwkw on this guys, so I've got a feeling it's one of those "conservative" figure producing dynos. Maybe I've got 150rwkw - who knows? - and who cares now that I've got the whhoooooossshhh back - and the punch wherever and whenever I need it.
iijj
PS wonder what 11psi feels like....hmmmm....just for a blat, maybe!?!
The SAFC will not change fuel economy of a car, cos at low rpm where the car spends most of its time, the ECU is running closed loop (and the SAFC's low throttle map corrections are cancelled out in the end) Only at WOT if your leaning it out some gains are to be had, but WOT chews fuel anyway!!! My fuel economy got worse when I got my SAFC, because I put my foot down alot more now :)
Hehe, you make too many assumptions about my driving style :)
But yeah, I agree you won't much difference on the highway cycle economy. But with a lot of stop-starting, it can be slightly improved with the S-AFC, especially if you have your foot down a lot.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
