at uni a few years ago, one of the electronics guys had a "really expensive" multimeter which measured ohms very accurately - ie accurate enough to find short circuits in circuit boards etc.
now the only multimeters ive ever owned have no where near any kind of accuracy close to 0 ohms...ie shorting the leads gives u 0.5ohms and definitely no precision.
most of the need for the multimeter would be detecting points of short circuit, secondarily all the common stuff, and optionally a frequency counter/measurer. any suggestions?
You'd be looking at something like a low ohm meter, or microhmeter for that sort of measurement. Most of those insert a current through the part to be measured and reads the volt drop across that part, not really the thing for finding shorts on boards.
A fluke 87v or 189 has a relative function, to zero out the lead resistance.
I've been testing multitapped transformer windings with an 87v recently, resistance between these winding sets was in the range of .1 ohm difference to the next tap. Seemed accurate and repeatable.
Another way to chase shorts in circuit boards is to inject a frequency into the track, then use something very similar to an inductive pickup (hall effect maybe) to chase the path and follow the signal. I've only seen one used once and have no idea what it was called, so can't help there.
ps. That consult cable works great. Pity that I have a pfc turning up and probably will be selling it soon. Ecutalk is bloody brilliant as well.
james.
Edited by heller44
the relative thing sounds good. though on small circuit boards, im not sure if the resistance on tracks that are like 1cm long would be in the range of 0.1ohms
an example of where id use it is ive got 5 of the tiny smd boards from the consult cables that dont work, almost certainly because of shorts somewhere in the smd soldering
working on an update for ecutalk atm :rolleyes:
I ended up with the Meterman 38XR and will get the RS232 cable and disk in the near future . A fellow I know who used to work with industrial scales has a Fluke 225 which I think is no longer available . If he ever gets sick of it ...
Cheers A .
3.5 ohm is a real bad reading for leads.. I'd be looking for another set of leads, then another meter definately.
An example of the resistance for a short length of copper, 25 AWG wire (0.163mm2) has a median resistance of 32.37 ohms per 1000ft. 1ft resistance is 32.37mohms, 1cm is 1.062mohms. Pretty much near on squat. Copper tracks are a bit harder to work out because different manufacturers use differing thickness copper layers. But you get the idea.
Best bet will be just to work through the circuit, since you have the luxury of having a small board (not very complex) and the schematic for it. Even with a cheapie you should be fine. A judicious use of the ohms reading and the diode test fuction and you should be fine.
The min/max function picks the minimum maximum and usually average level measured whilst the min/max funcion is enabled, one issue is with most meters the scan rate is slow and very quick transients can be missed but for auto stuff it shouldn't be an issue, if it is then a scopemeter will need to be used. The hold fuction only holds the value that is on the screen at that time, so you need to be able to watch it and hope that it doesn't go higher, or lower if that is what you want, after you hit the button.
If that is a 125 fluke that would be good for auto stuff. no idea what a 225 is..
Hope that helps anyone. (I think i was bored.. :thumbsup: )
james.
edit for screwed up my maths. damint.
Edited by heller44
    • Steam valve seals are usually responsible for cold start smoke, it goes away once engine warmed up. Disconnect it let engine breathers and let it breath freely, see if problem goes away after a short drive. Also check to make sure engine oil drain pipe is not blocked or kinked.
    • Haha thanks! Yea I'm moving over from 2x 1000cc jets pre throttle over to 6x 190cc direct port jets and 1x 500cc pre throttle jet.  Direct port comes with all the advantages you would expect, except that pre throttle does cool down IAT'S more. That's why my direct port nozzle placement is closest to the plenum as possible in the runners to allow the air more time to cool before being sucked in. I'm also putting that one 500cc pre throttle jet to help with more cooling. It's a hybrid system. There's a lot more advantages to moving over to a PWM solenoid with a constant pressure system vs my old PWM pump setup, but I'll get more into that once I'm done converting everything over. The ricer in me is excited to see SS tubing all over my manifold though!
    • Very cool, see what I did there? 馃ゲ Wild WMI setup, first I've seen where it's on each cylinder runner, usually I see a single jet pre throttle.
    • Welcome mate. What type of work were you looking at getting done? Majorly of decent skyline workshops are in the SE.
    • Thanks mate, haha that's it ey, no more boosters and what not, should make for a good time
