Sau Vic Track Club Championship - Round 6 - Sandown Sprints - Sunday 19th August
  • Replies 170
Posted Images
Hey guys.. just a question regarding the seat belts...
in the supp regs it states
"Must be fitted with seat belts to AS E35 or of a type
listed in Section 6. Schedule I of the 2007 CAMS
Manual of Motor sport."
Can someone translate that into something that i can understand haha?
cheers.
Mark,
It basically means that the seatbelts supplied with the car from the factory pass as do any approved harnesses (the ones that carry a certification tag on them) as long as they have been fitted correctly.
Think ill be attending this one as well.. after doing Winton in the dry (unlike Calder in the wet) was awesome and i have caught the bug.. just need to sort out some new tyres as Winton munched them bad.
I'm in! Just need to get my car fixed, I think it's the alternater, will be fixed before the end of next week.
I have two more events before Dutton to get this fixed, Sandown and Deca. I just hope the egnition doesn't cut out at Sandown going into turn 1 or turn 4. That doesn't sound like much fun!
Might be worth going to a track day (If there is one!) on the 12th of August at Sandown or Calder to see if the problem is fixed at least that will give me an extra weekend before Dutton...
Goodwork Juzz, im in too! lets see if we can break our cars for dutton! If it is going to break i would rather it be now than at dutton tho.... that would be gay.
Should be good to see the invasion of the Dattos again also.
I'll be at Sandown on the 12th August Juz (HSV Club).
Link to Entry form for you - http://www.hsvownersclub.com.au/HSVOC_Sandown_12_Aug_07.pdf
Sorry Mark, (Paradizzle) for not catching up to you at Winton. Good to read you enjoyed yourself:)
If you are looking at doing DT its always easier to get it sorted before the day. So shoot a PM to the usal suspects like Scotsman, ADZ, Snowman, Belsil80, Aaron34, JAGR33, me etc and get it locked away before the morning.
Dont be shy, doing Driver training is awesome fun for instructors so all we need is the invite.
All good mate, i might catch up with you at Sandown if your heading down.
Would be good if i can get a driver instructer with a rear wheel drive car as last two times i've had an EVO driver who wasnt sure sometimes on which lines i should be taking... but none the less he helped heaps! So if you can point me in the right direction so i can PM someone with RWD exp that would be great.
cheers.
EDIT: I have a AASA licence is that valid for Sandown, or do i have to purchase a CAMS licence?
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
