Sau Vic Track Club Championship - Round 6 - Sandown Sprints - Sunday 19th August
  • Replies 170
Posted Images
Yeah, he was quicker than me all day. But i was happy with a 1.32. I only did two or three sessions out there so i was very happy with my time, and only 3 seconds off the pace of the owner. Oh and no i dont fit in the car all that well, dutton will be intresting.
yeah its pretty embarassing when someone jumps in your car and is quicker than you :D:)
so Ryan was in the 1.29's hey... was this on RE55's? cos if it was I think he has a couple more seconds in it still... I've done a 1.29 around there on streets with the speed limiter on and I think our cars are similar power/weight
its hard to drive a car fast that you aren't comfortable in but you should have plenty of practice adapting to different cars :)
I ran a 1.19.32. Handbags ran a 1.19.37. As my friend Vin says "It doesn't matter if you win by an inch or a mile...." :)
Scotsman only ran a 1.21.something as he was caving under the pressure. :D
In my defence it was the breaks that caved under pressure.
But the car is capable of a 1.19, so that's all I need to know.
My times have got me stumped. there is still a bit in it but i wanted to take the car to dutton in 1 peice. 150rwkw for the lose. Sandown is a power track!
Troy what was your time
I didnt actually run so my car is still in one piece :domokun:
Meh, after your cheap shot at my car. Coming to a track day with not enough pads idoesnt fly. Hell, even i changed my pads on Saturday as the old ones were a little past 50% :D:):)
Sure sure, go back to the drag racing!
Yeah but Handbags ran the 1.19 AFTER you ran the 1.21. So surely he had less brakes than you did :wacko:
In Chris's defence he did not get a clear run it that sesion at all. The brakes had absolutly had it by the time I brought the car back. Peddle to the floor and used about 30% of the pad in one sesion. The only thing in my favour was that there was a bit of rubber on the track and it was as warm as it was going to get. I seriously think the car can run a 1.18 with good stoppers.
Oi and snowy running in the teens doesnt make you a good bloke. You need to buy me a frigen burger rather than sending me to the back of the line to achive that. :(
was good to watch, curious on what speeds u guys get in the GTR's on the straights? looked like you were flying.
"Teh GTR will neva lose"
or what ever that sticker was, made me laugh :laugh:
was a top day!
the 'bird was performing pretty well, still suffering a lot of understeer, and can't get the power down out of corners as early as i'd like.
blew an intercooler hose off in one session, progressively lost the manifold-turbo gasket throughout the day and an O2 sensor that refused to stay in its hole.
little problems, but enough to see me only get two timed sessions before calling it quits. but not to worry, had heaps of fun in my final session and took a second off my PB, down to a 1:33.2
car's still got a fair bit in it, my testicular mass is the limiting issue :laugh:
desperately need a tacho. after watching the in-car footage, i realised just how early i'm shifting! she was cutting out at about 190-200km/h in 5th, but we know it's not the speed limiter, so thinking it's the AFM maxing out. bugger.
...and good footage Jack. But what happened to the Stig...LOL it looks like you were driving ANGRY today :laugh: But parkign it on the 1:18s all day. Fark me that take a lot of committment
The Stig was on a mission for a 17, but driving with anger was not going to cut it.... Smooth is the Stig's style, but the gearbox wasn't up for another session...
Although it was great entertainment for the spectators, so I was told anyway.....
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
