I changed the O2 sensor on Sat and so far haven't noticed any change in fuel consumption from the first 1/4 tank. Do i need to reset the ecu? I disconnect the negative terminal and stomp on the brake pedal a few times right?
Is there anyway of checking the O2 sensor to see if it's connected alright? My crimping skills aren't very flash :glare:
Car is a S2 Stagea, RB25DET NEO.
Thanks!
https://www.sau.com.au/forums/topic/178802-just-changed-o2-sensor/
I just did the same thing too mate. I reset the ecu as u mentioned above and i feel that it did make a slight amount of difference. Haven't driven the car enough since to really tell about the fuel econ. If you want to see that the sensor is working you can cut some of that black tube cover away just after the plug where the sensor plugs in. If you have a look there you will see the plastic insulated wires there. If you have a sharp knife you can shave some of the insulation away to see the signal wire. I did this and hooked my multimeter up to it to read the values. An analogue meter might be better to use for this testing.
I read somewhere on the forums that sometimes the engines needs a week of driving to "learn" before you see any affects of the new O2 sensor so i will keep an eye on it.
I don't have a multimeter so it might be something the mechanic does when i take it in for a tune in a couple of weeks. I'll try resetting the ecu though.
Cheers.
hey webng just wonderin were u got and how much the new o2 censor was
Got the NGK/NTK OZA395-E2 from Petroject in Stepney, Adelaide for $78. Unfortunately the plug didn't match so I had to cut and crimp the old plug to the new sensor. Didn't take too long but I would highly recommend getting a sensor socket, a lot easier i'd imagine!
Apparently the original Nissna part cost double that. I was quoted about $160 for a workshop to do it.
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
