Hi All,
I am looking at putting a td-06 25G high mount with external wastegate on my 34 soon and am wondering whether i should gone down a different path or not.
The mods on my car so far are:
Blitz twin plate clutch
Blitz front mount
Walbro Fuel pump
Pod filter
AVCR boost controller
PFC (not installed yet)
550 cc injectors (not installed yet)
Future mods before turbo:
260 degree Cams
Cam gear
oil cooler and remote oil filter
Looking for 250 - 300 rwkw.
Just want to see peoples opinions.
https://www.sau.com.au/forums/topic/178807-td-06-25g-on-r34gtt/
Looking for response more than out right power as i am not planning on doing a rebuild in the near future.
Otherwise i would be going down the path of a t04z and chasing over 400 rwkw, but i want to use this as a street car and the occasional track and drag day at this point.
Thanks MADGT4 for your response as there is one in the for sale section i am looking at purchasing but didnt know whether it was a good idea or not.
That is the purpose of this thread :glare:
What size housing is the turbo your looking at?
But i cant speak from experience though only from what i hear/read so i would possibly try and find someone that has a similar setup or better knowledge of the turbo.
At the end of the day from what i know though it is an ideal turbo for the 25!
td06-25g probably isnt the most responsive of the turbo range but makes up for it in power delivery i guess, try a gt30 or a 3037s for more response. I am a BIG fan of the td06-25g's so i would still say go for it, be a tough car then :D
depending on the housing size it will easily match a GT30 for response, in fact a T67 8cm (very similar) we did recently shat all over the GT30 the differrence in response was like 40rwkw between 3000-4500
260 degree Cams
Cam gear
if you are just looking at <300rwkw with top mount td0625g you will need none of the above, although oil cooler would be a good idea for track use.
you could easily get 280-290rwkw from what you have already but dont forget z32 afm.
cheers
yeah ex housing choice will change rpm response alot, a mate of mine had the smaller td06-20g on his r33 gtst not sure of ex housing size but it didnt hit hard till between 4500-5000. nice once it was on though..
It is said to be the 8cm version of the td-06 25g, so should hopefully be not too laggy.
I have two mates in Adelaide who have been driving around with 300rwkw for 4 years and have not had a problem and they drive there car everyday as well as doing a couple of track days.
I think it is more about the tune and support mods as well as the way you drive the car to how long your engine will last.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
