Hey guys
i have an R33 gtst which is fairly stock - FMIC, 3in exhaust, pod. i am currently chasing around 250 - 270 rwkw, car will be mainly used for street but also a bit of circuit and 1/4 mile.
i am in the process of buying all my mods and installing them all at once, saves me on ru-tunning costs.
So far i have bought:
720cc sard injectors (top feed)
sard fuel pressure reg
greddy fuel rail
bosch 044 fuel pump
greddy plenum chamber
haltech ECU
blitz dual selnoid EBC type R
cam gears + timing belt
All i want now is a high flow turbo and cams.
With the turbo i dont wont a huge lag machine but i want something that when boost kicks in ill get punched into the seat, plus it will help with getting of the line if the turbo isnt super responsive. Reading all the threads im inclined to get a HKS Gt-RS or a GCG high flow but dont want to spend 2k. is there any good garretts for around $1500 which will get me to my goal?
With cams not to sure whats good but i really want cams that will give me that nice tough engine note, nengun have some HKS cams: 97/8 Duration - 256, lift 8.8m http://www.nengun.com/hks/camshafts-nissan 2202-RN172 /3 which are fairly cheap but any suggestions will be great.
thanks
https://www.sau.com.au/forums/topic/178810-not-another-turbo-thread/
I dont suppose your Series II is after a 97 model?
If so, there's some freegan cheap Cams in the for sale section.
Tomei Poncams for $600 !
I nearly went for em myself but it's just that bit extra cash i can't deal with right now, dealing with a new clutch and installation :(
The GT-RS is a hard act to beat.
A Garrett cartridge that would go close to the target using OE housings would be 446179-5032 - The 56T GT2871R. But you'd want a good idea of the costs of oil + water lines for the total cost vs HKS product.
Try a search on cams. There is plenty of comment about whether cams are justifiable at the power level you're targeting. I'd say the overall efficiency would lift with them but the raw numbers not show a large improvement from stock. At $700-$1000 fitted and installed you'd have to ask whether a changed exhaust note is justification enough.
Nope.
$1750 at the bare minimum, and then add installation, dump pipe etc etc.
Around $2300 at least.
yeah i have read a few topics about the minimum gains from cams but later in the future i plan on doing forged internals so i might wait till then and get it all done together.
I have been going back and forth from the GT-RS and GCG highflow so many times it makes my head spin. Correct me if im wrong but you should be able to get the GT-RS kit for around $2500 so i was thinking get that then sell the standard turbo to recoupe some $$$ losses.
Anyone 2 wanna take me for a ride with each turbo so i can feel the difference :D
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
