saw a black Audi R8 and a white Audi R8 today
damn these things are starting to become common, 2 in one day :devil:
also thought i'd mention a white 300zx convertible, even though they are not super they are prety damn rare
Went for a day trip to the Mornington Peninsula today and godDAMN there were some nice cars around. Guess it's good friday so all the richies with their Sorrento holiday houses are out in force.
Saw two Astons (one of them a DB9 with plates [308], the others non-custom), two 911 turbos, a 911 GT2, and a gorgeous RR Phantom Drophead!
Also a shiteload of black and white M3s, Lotus Elises, and Porsche Boxsters.
Finally got to see one of the new Camaros the other day!!
ZOMG i almost peed myself. :banana:
Not a huge fan of the yellow but still.
saw a black convertible one in springvale a while ago. was stunned and forgot to go when my light went green till i get a toot from the car behind me
What set the roll bars off?
Just parked it out the front of the house.
Seems like Astons worst enemy isn't people rolling them in 007 films, its putting them on quiet streets and scaring them from behind. :(
How the f*ck did that happen? :(
Did you bring the roof down with those two (are they NOS bottle enclosures lol) in the rear?
And I must have missed when convertible soft-tops converted to real glass rear windows...
lol, as above they are roll bars.
They are supposed to explode up in the event of a roll over to protect the occupants being a rag top.
Unless the earth decided to fall off its axis from someone dividing by zero i am lost for words.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
