Super-spotted Thread
Jamezilla
saw a black Audi R8 and a white Audi R8 today
damn these things are starting to become common, 2 in one day :devil:
also thought i'd mention a white 300zx convertible, even though they are not super they are prety damn rare
Went for a day trip to the Mornington Peninsula today and godDAMN there were some nice cars around. Guess it's good friday so all the richies with their Sorrento holiday houses are out in force.
Saw two Astons (one of them a DB9 with plates [308], the others non-custom), two 911 turbos, a 911 GT2, and a gorgeous RR Phantom Drophead!
Also a shiteload of black and white M3s, Lotus Elises, and Porsche Boxsters.
Finally got to see one of the new Camaros the other day!!
ZOMG i almost peed myself. :(
Not a huge fan of the yellow but still.
ZOMG i almost peed myself. :banana:
saw a black convertible one in springvale a while ago. was stunned and forgot to go when my light went green till i get a toot from the car behind me
How the f*ck did that happen? :P
Did you bring the roof down with those two (are they NOS bottle enclosures lol) in the rear?
And I must have missed when convertible soft-tops converted to real glass rear windows...
What set the roll bars off?
Just parked it out the front of the house.
Seems like Astons worst enemy isn't people rolling them in 007 films, its putting them on quiet streets and scaring them from behind. :(
How the f*ck did that happen? :(
lol, as above they are roll bars.
They are supposed to explode up in the event of a roll over to protect the occupants being a rag top.
Unless the earth decided to fall off its axis from someone dividing by zero i am lost for words.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
