Super-spotted Thread
Jamezilla
why? i'm sure he has worked hard for it...
May have. may not have. I'm sure Paris hilton has worked hard to not have to work a day in her life either :thumbsup: That's not the point though. Why spend that much on a licence plate of all things?
Could buy a nice house for that price.
a nice house AND that car.
May have. may not have. I'm sure Paris hilton has worked hard to not have to work a day in her life either :D That's not the point though. Why spend that much on a licence plate of all things?
Dude seriously, I'm sure the owner of that plate spent that much money on that plate because he has lots of money to spend.
If you think he's only worth the amount of the license plate and that car you'd probably be mistaken.
2.1 mil is a bargain.
I remember some young Saudi Prince bought the Number 1 plate in UAE I think for US$15mil. And he's putting it on his bedroom wall instead of one of the many supercars he owns.
To clarify i was pointing out it seems like a waste of money to me.
I wish i was in that position, because you know that if he/she's spent that much on a number plate, he/she's crossed a lot of things off their 'things to do with my money' list to get down to 'buy an expensive numberplate'.
plus, it's probably the only truly unique thing in the auto industry these days. There always a chance that someone else will pull up next to you in an identical murcielago/reventon/Aston DBS but no-one will EVER pull up next to you with the #1 numberplate.
you know what i mean, the odds of someone with a single digit plate being nearby are astronomical (that being said, i followed "27" down the monash a few weeks back) - if you decide to go for a personalised plate the individuality isn't nessecarily there is "SKYLIN", "SKYLNE", "SKYLN3", "SKYLYNE", "SKILYNE" , "SK1LYNE" and the infinite number of permutations mean you 'individual' plate isn't as individual as you might think. Whereas, single digits, well, there's only nine of them.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
