Super-spotted Thread
Jamezilla
A quick run of the rego seems to show it's real.. I think?
Vehicle Registration: URA259
VIN/Chassis Number: ZA9C005A0GLA12912
Engine Number: L507V41118
Vehicle Make: LAMBORGHINI
Vehicle Colour: BLACK
Body Type: COUPE
Year of Manufacture: 1986
You work for Vic Roads?
:P
:P
Haha if I worked for VicRoads, I wouldn't put information like that up coz they'd probably fire me :banana:
But it's all available freely online for vehicle checks! :banana:
Online vicroads status most likely
VicRoads: Vehicle Status Checks
Haha if I worked for VicRoads, I wouldn't put information like that up coz they'd probably fire me :P
Ah I see!
Thanks guys!
Damn, it works too, I did a check on my cars and all correct.
  • 4 weeks later...
Saw that same black Lambo driving past me on Burwood Rd yesterday while I was walking from my car, Awesome thing you can hear it coming from a fair way and when he backs off it spits flames and splutters all tough like :P
So things spotted in my recent adventures...
Masrati Granturismo S, wearing plates that read "Consulate" instead of "Victoria....."
AM Vantage Convertible
C63 AMG with three digit plate (found an SL55 AMG with "27", but it was too quick to shoot)
Ferrari F355, Beachfront in Lorne
Also seen, but not shot:
Bentley Azure in Lorne
R8 on Warrigal Rd
Bentley Continental GT in St Kilda
Ah I see!
Thanks guys!
mine says the year of manufacture is 2008. everything else is right but that, so that means i have the newest r34 you can get lol. it should say 2000. should i get it fixed or doesnt it really matter.
edit: it says 2008 on my rego sticker as well.
  • 1 month later...
Didn't get to grab a photo as it went SCREAMING PAST
but i seen a
Lancia Stratos
Lancia-Stratos-HF-Group-4-
i see heaps of nice cars around my work everyday ranging from Formula Fords to Porsche GT3's, R8's, Aston's, Ferrari's, lambo's
I work in the industrial area in Braeside heaps of rich pricks over there and many racing team garages around
LOL!
Maybe you should get it fixed up.
Incase the info does not match up, it may cause issues later down the track.
Same thing happened to a friend at work. His car had the compliance done in 2008 and instead of putting in the build date at vicroads when it was registered, they put in the compliance plate dates. It was funny at the time a 2008 R32!! He just took it back and they fixed it up.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
