  • 3 weeks later...
I thought the guy ran his own business? There was a post on one of the Facebook groups showing a bunch of supercars roaming the streets of Melbourne with this one included. The guy who owned an R8 ran the business DoYouEven (which has over half a million Facebook likes) and I'm assuming this guy is into something similar.
Some nice cars out and about during the GP weekend.
Apologies for horrendous photos. I've never shot at night before, and we'd had a few beverages at crown before heading out into the evening.
Ferrari 599 GTO at the Crown Metropol
Audi R8 GT spyder and 'normal' R8
It's a bit of a tradition for the Ferrari Club to head out to Lygon street after raceday for dinner. Pretty lackluster this year, only about 6-7 cars there. Last year there was probably almost 20+
Still, wasn't all bad :D
Also, was at qualifying on saturday. Peaked over the fence of the Mercedes corporate area and saw an SLS Black Series they had on display
Also saw my first F12 in the flesh at the GP
Edited by alex182
  • 3 weeks later...
Just saw number plate "2" on a grey Ferrari on Toorak Rd.
Curious if the owner would feel elated pulling up next to number "1" or a sense of inferiority...
number 1 used to be on a 997 porsche turbo. guy had it up for sale and photos were taken at his villa. price did not include plates (obviously)
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
