just about 10 mins ago (its now 3am) a black R32 on p plates...rims, zorst, looked like an aftermarket FG or CF bonnet on springvale rd.
i was in my mates CA 180, with 3 other blokes...
top blokes to have a chat to!
and the owners R32 went pretty hard! has SAU stickers on it...
pm me if your on here, im from glen waverly...
yeah i havent posted in this topic for a while but it was supercar sunday for me so i might share.
Saw the lotus club doing the rounds through reefton area, as well as the Ferrari club. maybe they had a joint cruise or it was coincidence. but it was awesome seeing soo many red ferraris on trip.
then i saw more Ferrari's, red in colour, yellow in colour, one driven by balding man showing his shiny patch and giving his car a bit of a stick, and bald man hiding his shiny patch with a Ferrari cap and jacket. spider/convertable Ferraris, new and old soo many prancing horses that youd think that they are a new taxi ;-)
what delorean?! pics dream car god damn so excited!
looked exactly like that :teehee:
never knew those cars were wide - but it looked very very wide - and in mint condition too
dont think it would be a supercar, but its one that is very rare
looked exactly like that :D
now figure who it belonged to :D
http://www.ozdelorean.com/
Saw a black countach on Sunday which looked just like this. The funny thing is how small these things are in real life - especially the rims. 15" rims are tiny by todays standards. Although 12" wide is still massive!
Saw a black 2 dr Maserati. Must be new as i hadnt seen this shape before and it looked mint. Had the licence plate GZ or something.
That and the 575LM that is in the apartment block next ot me these days...full of little add ons that makes me think the LM is a limited run of them or the owner used to be an EVO owner :D
Actually have a quick look at their website it was a Granturismo...great looking car. Easily tyhe equal of the DB9 in the look sdepartment
were the plates RUN4IT?
seen him around my area a lot recently... he likes to give it a boot too:)
TB - the Mas is Bobby Zagame's personal Gran Turismo. Plate = BGZ
It's just stunning!
The 575LM is the race car. 575M is the standard name for the upgraded 550 Maranello. Is it black?
Might it be Steve Snowdon's club car?
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
