The one I saw was something along the lines of this, but had a higher roofline at the rear I think:
That'd be the estate (station wagon for us educated Aussies) version. Make it black with dark windows and it is a dead set Hearse for rent......
spotted a really REALLY nice AUDI R8 on burwood highway today i saw it pass knox. so i thought id turn round to catch up and check it out.. dam it was hot! cept the driver was a wanker loll. he was going up and down burwood highway for a good hour.. so this is what most people with really expensive cars do nowadays to show off there on burwood highway.. lol
Totally GOLD.......... :D
There was a strange noise - so we took it in and found a 36 year old Italian guy stuck behind the gearbox...
Ok, is it just me or is everyone else LOL at the most prominant tool on the bench being a 12inch shifter?
That is gold. What would Lambo owners say? seeing their car needs to be serviced and maintained just like any other car??
How much was the windscreen replacement in the Yellow Peril? About $13K and a week in the shop right?
ROFLcopter
Here's one for the train-spotters...
993 based RUF BTR-2
These things basically invented modern turbo-lag :P
very rare car, only 1 in Aus i'm pretty sure, i think the guy who owns it is a doctor, always used to be at Box Hill Hospital, i had heaps of photos of it as well
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
