Whoa, where did you see this? I've seen the ACT Number 1 (also on a Merc) but not the Vic one.
Damn, plates are worth more than the car.
That plate might be worth over a million dollars... http://www.caradvice.com.au/6764/number-pl...orth-1-million/
why? i'm sure he has worked hard for it...
May have. may not have. I'm sure Paris hilton has worked hard to not have to work a day in her life either :thumbsup: That's not the point though. Why spend that much on a licence plate of all things?
Could buy a nice house for that price.
a nice house AND that car.
May have. may not have. I'm sure Paris hilton has worked hard to not have to work a day in her life either :D That's not the point though. Why spend that much on a licence plate of all things?
Dude seriously, I'm sure the owner of that plate spent that much money on that plate because he has lots of money to spend.
If you think he's only worth the amount of the license plate and that car you'd probably be mistaken.
To clarify i was pointing out it seems like a waste of money to me.
I wish i was in that position, because you know that if he/she's spent that much on a number plate, he/she's crossed a lot of things off their 'things to do with my money' list to get down to 'buy an expensive numberplate'.
plus, it's probably the only truly unique thing in the auto industry these days. There always a chance that someone else will pull up next to you in an identical murcielago/reventon/Aston DBS but no-one will EVER pull up next to you with the #1 numberplate.
you know what i mean, the odds of someone with a single digit plate being nearby are astronomical (that being said, i followed "27" down the monash a few weeks back) - if you decide to go for a personalised plate the individuality isn't nessecarily there is "SKYLIN", "SKYLNE", "SKYLN3", "SKYLYNE", "SKILYNE" , "SK1LYNE" and the infinite number of permutations mean you 'individual' plate isn't as individual as you might think. Whereas, single digits, well, there's only nine of them.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
