saw a red 612 scaglietti in the city yesterday just parked off elizabeth street, very awesome, saw another one the day before (possibly the same one) in a carpark 2 blocks away in collins street being driven by a blondie lolz
lol, mate I almost offered to hand wash it for him on the provision of a test drive.
I only stop by those washes to give my car a high pressure soap and water touch up between hand washes. I was mortified! Then he planted it as he was leaving and I forgave him :ph34r:
I Have worked on both for these cars installing the incar cameras.
I was scared s#itless drilling a hole in the roof of both of these cars. :(
The Audi i did earlier in the year at Adelaide and the lambo at Bathurst.
<!--quoteo(post=5575143:date=1 Dec 2010, 09:08 PM:name=Topstage_S14)--><div class='quotetop'>QUOTE (Topstage_S14 @ 1 Dec 2010, 09:08 PM) <a href="index.php?act=findpost&pid=5575143"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->some in melb and some around europe.
nb the black mclaren Mp4 in Spain...woooowww!<!--QuoteEnd--></div><!--QuoteEEnd-->
Tough looking Mclaren, how is that MB C63 though... love the wheels.
lost my sh1t on both occasions!
  • 3 months later...
  • 2 months later...
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
