Hey all!
I've got a r33 s2 with a few mods done to it already, just wondering what I'd need too do
too get over the 220 - 230kw mark.
I'm contemplating on whether or not too get a SAFC-II or just too get a stand-alone ECU.
Of course I'd prefer going the SAFCII due too costs but i also want too make sure that it's
possible and that I don't stress my engine too much.
From what I've heard the SAFCII can keep pushing power until your standard injectors max out.
How much power can standard rb25 injectors make?
I'm also thinking of getting a GTR fuel pump or a Bosch/walbro.
Anyone know what power the GTR fuel pump can handle?
Also does anyone recommend any fuel pumps for the power i'm aiming too make?
My current mods:
3" exhaust
FMIC
APEXi AVCR
Exedy button clutch
APEXi power intake
Slide Stage3 high-flow turbo
Thanks!
Samir :(
https://www.sau.com.au/forums/topic/178851-how-much-power-can-i-make/
  • Replies 40
Posted Images
your running a huge risk over 220rwk with stock injectors. for the sake of a few hundred bucks get them changed. better than 3k for a rebuild. And if you want to make over 230rwk get a stand alone ecu. much better. theres no cheap options when looking at that sort of power
cheers
alot of speculations on "stock" injectors, every seems to have different results my stock ones were light purple in colour, i made 258kw at wheels on them, use a bosch 040 pump,
Hey,
Thanks for the replys guys. :D
So you made over 250kw on stock injectors?
That's awesome.
230rwkw is around the max.
I would go powerFC over a safc as you will want to continue upgrading later
Yeah later on i was going too go for a standalone ecu
but i was thinking that if a SAFCII can handle the ammount of power
that i want for now, i'd go for it! Also if it's safe ofcourse.
it did lean out towards redline. car was never intended to make the power it did, i went to a dyno day for first time with new setup so had no idea wat the air/fuels or anything were doing, basically just said watch the air/fuels and it came up with that figure.. like others say though it isnt recommended, only reason i hadnt changed the injectors was i had no idea wat power the car was making or would make. cheers
stock injectors will work, duty will be close to 100%, then they fail..then u cry.
Haha, :)
Ok so, stock injectors... bosch040 or GTR fuel pump, Highflowed turbo, exhaust, fmic
With a SAFCII and APEXi Avcr... can anyone estimate how much boost you can run safely
or how much power you can go too?
Thanks
Samir
Haha, :)
Thanks
Samir
Cousin!! :)
Judging by the above replies it should be safe to push it to no more than 220rwkw with an SAFC II + GTR fuel pump.
At least you can check the knock and if we get it tuned on the dyno, AFR's will be spot on, but there is no room for upgrade once that is done. :banana:
Depends how much you want to go though, high-flow is more than capable of more, but injectors will max out and then you will need to get larger ones, then SAFCII cant support after market injectors so you will have to scrap that and go stand alone ECU..
If you want to get to 230 -240rwkw,you will need to go the following;
Bosch 040/GTR pump
Injectors - something like 550cc
Stand alone ECU + tune
So now your stuck lol.
If you want to go over 220rwkw it is recommended that you upgrade injectors, and you cant run after market injectors off standard ECU, so that means after market ECU..
Predicament!
Thanks,
Abu
Edited by abu
Haha, :)
Thanks
Samir
should be able to run 12-13psi with the hiflow safely on the stock injectors which should see 220rwk ish and the other mods stated.
12-13 psi, everyones got different oppinions but if u got a highflow hell push that shit to 14-15psi for high boost occassions
whats the point of getting a high flow without having that extra boooooost
man 12-13 psi i run on my stock turbo its been like that for over 1-2 years man
go for gold dude and ask the guys thats tuning it for ya
You cant push it to 14 - 15psi without a tune as it pings and timing retards etc..
Its not safe and you are guaranteed to blow something on standard ECU.
Even with his car on 12-13psi it leans out and starts to ping. 12psi MAX is safe on STD ECU with supporting mods and a fuel pump..
Stock turbo MAY be able to hold 13psi as it flows less than a high flow turbo, so it doesnt need as much fuel to back up its 13psi like a high flow does.
Big turbo at 14psi, for example, and a small turbo at 14psi are 2 totally different things!
Thanks,
Abu
Edited by abu
Thanks,
Abu
exactly right. 12 psi on my stock turbo, i was making 175rwk. now with the hiflow im making 209 on 12.5psi, with the stock injectors, stock fuel pump and afm. i cant go anymore than that... well i could but it wouldnt be safe as my injector duty cycle is touching 80 % now and pump nearly maxed out.
ohhhi wasnt refering to a stock ecu i was refering to a stand alone ecu :thumbsup: my bad
this biggest shit thing on our cars is the ecu. everything is a hassle because its just plan shit!
Edited by Zas)-(
Hahah lol ease up.
Although, once you have a stand alone ECU its all fun and games after that. Possibilities are endless.. until the injectors max out.. and then the turbo, and then the engine gives in!..
But seriously, getting the car tuned gets the best results! You see so much gain and improvement across the board with a good tune, there is no supplement for that!.. :)
Thanks,
Abu
Edited by abu
yeah best way to no wat boost to run is to take it to a dyno once mods are done, and up boost accordly, while watching air/fuel ratio from dyno. best way ;) i had not put my foot down through 3rd or later gears till i had it on dyno with new setup just to know what a/f rati's were doing.... goodluck
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
