I would expect any of the transporters would give you a good rate back from Brisbane. The majority of trucks must come back empty, so any $ is a bonus for them.
EDIR: Sorry - you're going TO Brisbane (my bad reading).
Yar thats right, only cos me 400 to bring my car down here but I think it's closer to double that heading up there. I used Patricks when I brought my car down was organised through someone a friend knew but no issues at all.
i have a week a off ill drive it up for you for the cost of petrol you can pay my flight back lol
Or you could drive my new 180B SSS back!
But I think I'd like to truck it - it's a 1-owner 1973 model, with only 22,300 MILES on the clock. Driving it back would nearly double the odometer LOL
Just asked TNT who pointed me to CEVA Logistics (1300 655 594). They quoted $470 to bring car from Bris -> Mel. (Mel -> Bris around $800)
Toll Logistics quoting $427 Bris -> Mel
Not listed under "SMB". Closest is SMB Fleet Management (Novation Leasing)
Not sure what they call themselves but SMB stands for 'Sydney, Melbourne, Brisbane'..
I see their trucks on the road all the time....
Found SMB:
Sydney Melbourne Brisbane Car Express is a Car Transporter located in Williamstown VIC Australia
Where is it?
11 Fink Street
Williamstown VIC 3016
How to contact them?
(1800) 262085
Or it might be:
Unit D, 55 Cherry Lane, Laverton N
Ph 1300 362 085
Email:[email protected]
Anyway, I've sent them an email enquiry - see what happens.
Hey mate, have u called around and asked about back loading your car? We did it for a mate of mine with his ceffee, only problem is that you would need to find a place where you aren't required to hold an account. When we did it we used the joint that my dads business deals with so we got good rates, best bet is to call around and ask about back loading.
Alternately have you looked at wacking it on a train? They run to Sydney then up to Brisbane, I have no idea about this, but just some food for thought.
Edited by ardie
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
