Sadly i've decided to not continue on with my rb25det silvia project, and sway towards the sr20 due to a few reasons... mainly i don't have the time or money to do it. All these parts came out of an R33 GTS-T, i think 95 model from memory, with about 130,000 ks.
RB25DET ENGINE DEPOSIT TAKEN
I just changed the idler and tensioner bearings, timing belt, water pump, power steering belt, alternator belt with genuine nissan parts (i have receipts... over $500 worth alone, at trade prices not including labour). plus i have 6 new spark plugs and two genuine nissan oil filters i'll throw in. I removed the air con compressor, but i'll include it with the engine. Front cover and coilpack covers freshly painted with high temp engine paint. Everything minus turbo included. Has been compression tested and returned a consistent 185psi across all cylinders. Never seen more than 16psi. It's killing me downgrading to an SR. :)
Save yourself the hassle of changing all the above parts when you buy a new engine and get this one.
Price is $1600.
RB25DET GEARBOX DEPOSIT TAKEN
This gearbox is in great condition. comes with a Single Plate Ceramic Clutch (Very Heavy) and all manual pedals, master cylinder and slave cylinder. It's a complete manual conversion for any R33 with balls.
Price is now $1650 for all the above parts and the flywheel and tailshaft.
ITS 460hp Turbo DEPOSIT TAKEN
This is a turbo from ITS (Innovative Turbo Systems in the US, not a dodgy china copy turbo). It's a 460hp Hybrid T04e Turbo with polished compressor housing. Only a year old. There's a bit of shaft play in the exhaust wheel, which is fine considering it's non ball bearing. Still spools up perfectly fine and makes plenty of power. Needs new wastegate can however. will throw in custom polished elbow off compressor. Cost $2500 originally.
Price: $800.
Garrett Front Mount Intercooler Kit DEPOSIT TAKEN
This is a fmic that was supplied by WASP performance in QLD. it's got a garrett core, with a piping kit.
Price - $400 Price dropped to $340!!
Wolf 3D V4 ECU (R33 Specific) - SOLD
Unlike most of the wolf computers out there that are universal and require hacking up your wiring loom, this one is r33 gtst specific, so plugs straight into your old loom. Also enables you to get rid of that AFM, saving you the cost of the z32. Comes with hand controller. New these cost over $1500 with the hand controller.
Price $1000
GFB STEALTH FX BOV (Atmo/Plumback)
Not much to say really. It's the same as the one in the link but in Red and to suit R33 gtst. Comes with the additional trumpet which is available for an extra $35. So that's $565 new from GFB. It's practically new, not a mark on it.
GFB Site
$400 delivered. Now $350 Delivered
Still undecided if i want to use or sell the rest of the bits, so i might update with more. For the moment these are the only pics i have, I'll take some proper pictures on saturday.
call on 0423 366 118 if you have any questions.
Edited by Julzy
and your a pussy..!! pussy..
Hey
Got pictures of the intercooler kit?
I assume it will fit R32 with minor adjustments? ;)
Thanks,
Abu
Will definetly fit onto an rb20det.
Ryan
i'm getting some proper pictures on saturday.
All parts are locate din Epping, Victoria.
I can post at buyers expense if he/she organises it.
PM me when you get pictures of the intercooler kit, I am looking at buying one asap.
PM me a rough price for pickup as well.. :sleep:
Thanks,
Abu
pics added of the fmic. as i said i'll take better pictures on saturday, but these are the ones i already had on my phone.
Above prices are for pickup, no delivery included (exluding the BOV). :unsure:
    • Hey looking for pointers or experiences with indicator wiring/ common faults for the blinkers on the r31, I have a 87 silhouette and am having dramas with the blinkers staying on (not flashing) to indicate right,while trying to indicate this way the relay makes a constant noise, The front passenger side fender blinker is missing the harness connector to the bulb so is not connected would this effect the opposite side? Both rears work as they should, and blinker that stays on functions normally when on hazards instead of indicating, have replaced all bulbs,fuses and relay Cheers
    • I’ll check the AFM’s and confirm. I’ve seen on another forum post years ago it’s identified with an orange sticker and larger diameter. Unsure if I can check the diameter without removing the air filter. Is there a way to identify if the AFM is stock? I’ve done a quick search and it looks like it might be a green sticker instead?   Will try check that turbo core tag. Looks like a very tight fit in there. Do you know what number would show if it was a stock T25 turbo?
    • The car and the 33GT-R wheels look great. I can't remember if spacers were needed for these but the offset looks perfect for the GTS25t.
    • And the lack of ubiquitous availability. If it was less likely that I'd run out of fuel while trying to cross the crime zone, I'd probably be all over it.
    • 98 dirty garbage, everything except fuel economy is better with e85
