  • Replies 44
bump....surely someone is interested?? would be a good option for any rb's that are going to be aiming for some decent power! great option for an rb30 rb25/30 rb26/30.
https://www.sau.com.au/forums/topic/178905-delete/#findComment-3292731
have u got pics of the exaust housing front on showing the exhasut wheel? this will also show me the type of dump we need to use. and also a pic of the t3 flange to confirm it is a t3 flange an will bolt up to the standard manifold?
https://www.sau.com.au/forums/topic/178905-delete/#findComment-3292958
i am unsure of the brand, and there isnt any making on it as to hint a maker
ooops i forgot to post pictures, sorry guys will do that now!! had a very busy weekend in the end
Edited by Turbz_13
https://www.sau.com.au/forums/topic/178905-delete/#findComment-3298662
Hey Turbz,
Is there any chance of having a look at the turbo this weekend in person?
If so send me a PM with you mobile number as i am interested but i want to have a look at the turbo first.
Cheers
Shaun
https://www.sau.com.au/forums/topic/178905-delete/#findComment-3298871
common guys it is a steal at this price!!! will post anywhere for $550!! i mean you could spend 2 maybe 3 grand on a HKS or trust item!! why when you can get the same performance!
BUMP
https://www.sau.com.au/forums/topic/178905-delete/#findComment-3327515
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
