Specs taken from GCG:
# Garrett GT2860R Turbocharger
# Skyline GTR Ball Bearing Replacements.
# Ball Bearing.
# Watercooled.
# Turbine Housing: Various
# Compressor Housing: Various
# Internally Wastegated.
# Rated: 400hp.
These are similar performance to the HKS 2530's and have been on my GTR for less then 1000klms and runs no more then 1 bar boost on a everyday basis.
<SOLD>
Edited by JUN R33
I think he means 1 bar. Even though, as far as I know the gt2860r-5's have their wastegate actuators set to activate at 1.7 bar total. So you've modified the actuators on it, or swapped over the ones from your standard turbos to run 1 bar?
