Hey all,
As some of you know I missed last weekends Winton round due to an expected arrival, and I wasn't disappointed despite it happening a day later!
At 7am Sunday morning my wife gave birth to a healthy baby girl weighing in at 7lb 5oz and 52cm long. Both bubs and mum are doing well and are expected to leave hospital this Thurs. As you can imagine both my wife and I are wrapped, and even more so we now have a pidgeon pair which is more than we could've hoped for. We named her Courtney Leah.
It was a bit of a rush to get to hospital as my wife was having major contractions on the way and we arrived with only 20-30mins to spare....as a result I am almost 100% sure that I have made a donation to the state coffers :) but if I had to do it again I would given the circumstances! Anyway the doc is writing a letter on my behalf so I will see how I go.
-Ant.
post-6243-1185918464_thumb.jpg post-6243-1185918471_thumb.jpg post-6243-1185918476_thumb.jpg
https://www.sau.com.au/forums/topic/178934-expanding-pitcrew/
Thanks guys and I will pass on your wishes to Nat.
All the best for the impending birth Snowie....being so close I didn't think you would make it to WA :whistling:
Lol James...we've pretty much decided that this is our quota so a procedure is imminent,after that I won't have to worry about keeping it in my pants....and depending who is going under the knife I may not have that urge to hump visitors legs anymore :)
Hehehe Scott....thats what cousins are for and the plus side is you don't have to clothe and feed them >_<
Cheers Paul....be sure to point Lauren in the direction of the thread so she can see the new arrival.
aww so cute!!
Zach looks like a very happy big brother >_<
My best wishes to you & your family.
So it looks like you won't be getting any more than about 4 hrs sleep for a while :)
Don't do anything drastic, I bet you'll change your mind in a few years when they're a bit older and annoy you constantly, and you wish they were cute, quiet little babies again. :whistling:
Lol....thanks guys.
congrats mate. time to get those pit crew jackets mits and boots made up.
Hahaha are you offering to knit them :(
so did you take the GTR to the hospital... haha 7,000rpm clutch dump into the hospital car park to handbrake turn in the ambulance driveway was totally necessary officer lol
While I did consider that for a sec the fact that leather is easier to clean than cloth (in regard to the passenger seat) and Nat would've had to wait until I had warmed her up didn't go in the R's favour :)
Only i think Brisberella would have been a beautiful name for a little girl.
Now thats a name....where were you when Nat and I were trying to decide on names?
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
