Hi, I was wondering if R33 GTR wheels are a good upgrade for an R34 GTT for track work? Do they clear everything, or are mods required and are the offsets suitable? Are they light and strong enough to make them worth using for this purpose? Thanks!
https://www.sau.com.au/forums/topic/179035-r33-gtr-wheels/
They clear everything and fit well, i have a set and they are good for track work as they are 9" wide and can take decent size tyres. The only mods you will have to do is flare the gaurds if your car is lowered.
https://www.sau.com.au/forums/topic/179035-r33-gtr-wheels/#findComment-3263542
235-45-17 is the perfect size for a 9 inch rim, especially for price, availability and guard fitment.
maybe wider on the rear for drag use, but otherwise no need.
cheap brands can be had for $100 brand new, but offer no grip. or up to $300 brand new with great grip
https://www.sau.com.au/forums/topic/179035-r33-gtr-wheels/#findComment-3270461
they should.
they will easily fit the rear, with the front it may depend on camber and tyre size as to whether they fit.
the rim will fit for sure, its only a matter of what size tyre.
i have seen many GTST's with GTR rims
https://www.sau.com.au/forums/topic/179035-r33-gtr-wheels/#findComment-3276258
how good an upgrade would you call them? did they make much difference to handling?
I had RE55S on them..
so HELL YEA! ahha
pretty heavy though, compared to the enkeis I used for the street.
Could feel the obvious difference in weight when you're turning the steering wheel
https://www.sau.com.au/forums/topic/179035-r33-gtr-wheels/#findComment-3279908
