for all the parts u need for the conversaion - it should cost around 500 bucks. u will need most turbo parts - ecu, injectors, manifold, turbo, lines, dump pipe, front pipe, intercooler, n also u will need to upgrade ur fuel pump..and then theres the cost of labour - im not too sure exactly how much thatll cost - everyplace is different, but make sure u shop around for a good workshop that actually knows about skylines.
hope that helps you out mate.
depends how much you want to spend and how good quality, how much you can do yourself and how much help you get from here if you havent done it before (i wasted money on some things that wernt every explainded on the forum)
you will need a good quality second hand turbo, prob want to spend like $300-$450 for that, make sure it comes with oil and water lines and the elbow pipe,
you will need a manifold prob around $100-150 but make sure when you get it isnt warped, grr mine was warped and blew my gasked and then had to take it off repace gasket @ over 110 a gasket from nissan, then get it machiened and put back on
for $50 its best to just get it machiened before you put it on for security
You'll also need dump and front pipe, prob $40-100
you'll need at least a manifold gasket but best to do turbo and dump gaskets about $180 all up from nissan
Intercooler and piping $50-$200
injectors like $100
ecu $50
best to do fuel pump to with a gtst item $50
or you could get an aftermarket pump and a regulator to get you threw till you upgrade injectors later down the track.
all these parts should get you going, if you got some sort of mechanical knowledge you should be able to put it together on your own/with a mate
if you got more money to spend id sugest the following
1. tuneable ecu
2. bigger fuel pump
3. bigger injectors
4.bigger turbo back exhaust
5. bigger brakes
6. bigger intercooler
7. better quality turbo, not so much bigger but better flowing ie garret or something
hope that helps as a very very short brake down on possible cost, plus best to plan for more money unexpected costs, but ey ends up a great car to drive mine hit full boost at like 1800 rpm
is there places that you can just take the car and like they buy all those parts for you and install it or do you have to buy the parts then take it to the workshop?
do a search but from memory there is a place that will do the conversion drive in drive out but the cost was more around the $4000 mark, which is about what any place would charge to do the conversion if they supplied the parts.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 馃槀  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
