hey guys i was just wondering i have seend a twin high mount manifold with only one pipe for the waste gate. i was just wondering what is the difference in performance with having one wastegate for two turbos to having two wastegates??
https://www.sau.com.au/forums/topic/179107-waste-gates/
i can't see how it would alter anything except how much air it can flow. i am assuming you are talking about external gates?
i don't think it could alter response from off boost to on boost since they would both be shut anyway as soon as the boost drops below what they are set at. so when you lift off on gear changes they would both close.
https://www.sau.com.au/forums/topic/179107-waste-gates/#findComment-3264782
technically 2 smaller gates should be a little more responsive as they are operating smaller, lighter valves but in reality the only reason you'd run twin gates is if there wasn't a suitably sized/priced one for you to run one big one.
https://www.sau.com.au/forums/topic/179107-waste-gates/#findComment-3264820
stupid noob question, but what are the advantages of having an external gate?
generally external gates offer greater flow and thus you get better boost control.
Internal gates can either be overwhelmed and be forced open at high boost levels which would result in a lower boost reading then desired or
when at high revs and high boost they may not be able to flow enough (ie too small) and this would create boost creep and you would have undesired overboost.
Thats why generally over 500hp, you dont really see many internal gates
https://www.sau.com.au/forums/topic/179107-waste-gates/#findComment-3266072
the tt supras jza80s run a single wastegate for both turbos, and with a simple exhasut made up it often makes them overboost cause the wastegate can't keep up with the two turbos. With an aftermarket system, it wouldnt make any difference with twin or single set up, as long as the size was right to handle the flow of the motor and turbo
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/179107-waste-gates/#findComment-3266075
Id have to dissagree to everything there except for the cost.
The original poster was considering a twin turbo setup with either one of two wastegates. Aside from the fact you have two wastegates and associated piping thats going to cost you more and theres increased manufacturing complexity, i would say the advantages of running two over one would be:
- You now dont have both manifolds connected! And hence cross flow and increased turbulence is reduced allowing improve flow (as it was intended in the original manifold design) to the turbines
- Response is not neccessarily improved because of the smaller, lighter valves (i.e. less intertia beer baron) but because of the improve flow
- Control is no different as with a normal setup assuming your running a pressure referenced linear diaphram actuator as was the case with the original skyline gtr
Asides from cost, technically two wastegates would be better for a twin turbo setup.
https://www.sau.com.au/forums/topic/179107-waste-gates/#findComment-3266408
that's fine, except that most (all?) twin wastegate manifolds for skyline 6s I have seen run a balance pipe to connect the two manifolds.
with response, I was talking about the response of the wastegates, not boost response or engine response, and two 40mm gates should be more responsive to changes in pressure that say a single 60mm, but again it would not really be enough to be noticeable.
but sure, twin gates is nice, and if you are running twin big turbos then it's the best option for sure. but for a single turbo I would always just run one big, single gate.
https://www.sau.com.au/forums/topic/179107-waste-gates/#findComment-3266615
I think running twin parallel turbos on an I6 and having a "balance tube" between the two manifolds is a stupid thing to do . One of the greatest advantages of having parallel twins is keeping the 123 456 exhaust events seperated . You keep the exhaust "putts" further (engine cycle wise) apart in seperate manifolds so that each cylinder blows down through each turbine housing and the pressure falls in each much faster before the next exhaust event . To be isolated eack turbo or manifold has to have its own wastegate and not share the exhaust pressure rise from the adjacent manifold .
If you cross connect the exhaust manifolds its the same as having a single turbo single scroll turbine housing . This system falls down because since every cylinder is venting into one passage (housing) there never is a low pressure period so you lose a significant amount of exhaust energy merely fighting a path from one end of each manifold leg to the turbine housing . Reversion is another significant negative .
My 2c spent .
https://www.sau.com.au/forums/topic/179107-waste-gates/#findComment-3266961
My 2c spent .
Exactly. I am for this very reason designing several prototype manifolds which will use a single twin scroll turbo and not less than two gates. Same reasoning as discos, completely seperating certain exhaust events (in my case 1-4 and 3-4).
Balance tubes or not having a splitter/divider seperating scrolls all the way up to the gate piston negates in almost everyway having a twin scroll system or in the case of a gtr, seperating 123 and 456.
Peace
https://www.sau.com.au/forums/topic/179107-waste-gates/#findComment-3268000
I think that was a typo , (1-4 , 2-3) .
There are some 4cyl twin scroll manifolds with a single wastegate but to have any hope of it working the division has to go all the way to the face of the wastegate valve , even this is not perfect because the divider must not touch the valve or it may not seal shut . If it was me with twins I reckon it'd be hard to resist the temptation to stay with integral wastegates because your getting twice the valve area . Also having the front and rear three cylinders isolated means that turbine inlet pressure will be lower and controlling the gates becomes easier because of it .
Whats a pair of 2530 IW turbos good for on a well set up engine , 600 odd Hp ? Maybe 450-500 if grafted onto an RB25DET ?
Cheers A .
https://www.sau.com.au/forums/topic/179107-waste-gates/#findComment-3268530
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
