Was about to start a new thread, but this might do.
I live in Cairns and obviously have a white GT-t.
More to the point, anybody know who the chick with the white GT-t is? Or the bloke with the clean grey GT-t? Want to catch up and get some pics of some R34s side by side.
  • Replies 100
There is a chick who drives a yellow R34 GT-T in the Woree/Bayview Area, also seen the girl driving the white one around every now and again. I also seen the Silver R34 GT-T on Australia day out near campus domino's, really clean looking R34. Was checking out the car till I suddenly realised that the guy must have thought I was checking him out and gave me a weird look, felt like a bit of a dickhead. There are also a few black ones running around.
I haven't been to a meet yet, so don't know many peoples names.
+1 for cairns. Moved here late last year. Keen for a cruise whenever. Look forward to the next meet. Have seen alot of very clean skylines around (and a few that deserve better owners :). Got a white gts-t, so will keep an eye out for fellow owners. Seen some very clean 34's getting around, very well kept rides. See ya's on the road.
Pretty sure I've seen you around, like a series 1 White r33? Whats your plates?
*** JIQ White wheels. Seen plenty up here. No one returns the wave though. Whats the best night to hit the road around here
Yeah I've seen you around. Thursday night is not a bad time to go for a drive out to the beaches (clears my head during the uni semester). Also if you think your the next Vin Diesel you can always hangout near Woree maccas, I do my best to stay away from there though too many 40-50 year old guys showing off their cars to 17-18 year old's when the should be at home with their wives and a lot of P platers showing of their '10' second commodores. Not my scene but different strokes for different folks.
Haha yeah I've had 2 people wave/nod back at me since Ive owned skylines. You give up after 20-30 unreturned waves. Makes you feel like a sped waving at someone and they look at you like 'who the f&*k is that' and keep driving without returning the wave.
  • 1 month later...
  • 3 months later...
Hey guys, so who's keen for a cruise? Couple people so far meeting up next sunday the 1st.
Head from Cairns up to port for a coast cruise. Good to see some new faces and some old ones. Maybe met a few people before.
  • 3 months later...
I'll be back in Cairns mid december if anyone's up for a cruise? Normally meet at smithfield, head up through mareeba, mt molly, and down via jelatton. 3 good ranges, normally takes most of the day and always a good drive.
I'll be keen mate, let us know when it gets closer.
Pretty sure there is a white r35 floating round FNQ
That's mine, you won't be seeing it around for a while, I lose my licence on the 26th. Got booked South of Ingham on the way to a track day - I'll be cycling for 6 months. :-)
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
