I am just about ready to send my engine of to be built and i have a few quotes and know the parts i want however i have heard a few story about my first choise engine builder.
ACT region is preferible but a trip to sydney (or melburne If Highly Recommended)
Just getting a basic rebuild and head service.
New rods, pistons, and n1 oil pump. + bore etc
Indy @ I.S Motor Racing in Rockdale: 95999918
Built sh!tloads of top RB's, knows them back to front, really knows his stuff. Everyone can say so and so is the best, but, I'm going off proven results. Currently building a friend's car/motor. Same setup(motor wise) in a different car gave results of 500+kw atw easily/comfortably.
Another good mob at building engines are Thornleigh Cylinder Heads. Speak to Nas @ 99809454
I would reccomend proegnines too. especially if you are in canberra. he has built a couple of motors for friends of mine, and if I had to build mine I would strongly consider going down there to do it even though I'm in sydney.
Theres some interesting rumours going around. I haven't shut down, I'm still at the same address, just in one workshop instead of the two I had before. I have got out of general reconditioning and am concentrating on this type of work, as well as producing parts like the sump adaptors and crank collars (and oil pump gears when I get some spare time.)
The easiest way to get hold of me is by e-mail, [email protected] or phone 0448 826256. I got rid of the landline as I spent all day answering it and couldn't do any work while I was. Leave a message on the mobile if I dont answer and I'll get back to you.
Cheers,
Greg.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
