Folks, have the following forsale
Project Mu SCR Pro 2 Piece Rotors - 800km old, in Original Boxes w/ paperwork- $450ono
- For S14, S15, R32, Z32 TT
- 280mm x 30mm 5x114.3pcd
- Caliper on previous car (AP caliper) fouled on ali hat. Markings shown. Bugger all
- $900 Rotors, but for you my friend only $450ono
- Half the weight of 26x280mm factory rotors! Unbelievable price!
Pics: http://members.iinet.net.au/~ketterj/cefir...le/IMG_3090.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3091.JPG
http://members.iinet.net.au/~ketterj/cefir...e/IMG_30921.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3093.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3094.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3095.JPG
Blitz BOV - Trumpet Exit
- 2 Bolt Nissan Flange included (bolt to SR intercooler, GTR, RB20/25 etc)
- Gasket
- $150ono
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3077.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3078.JPG
Ali Steering Rack Spacer
- CNC machined, Used for 100km then got a defect for it
- Suggest you paint it black before installing!
- $40ono
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3081.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3082.JPG
Polyurethane/Nolothane Gearbox Mount
- Black
- $50
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3080.JPG
RB20 / CA18 CoilPacks x6
- All working perfectly, Upgraded to Splitfires.
- $150
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3088.JPG
Rb20 DET East Bear Cross Pipe
- Slight wear mark from rubbing on bonnet heat sheild.
- Comes with timing belt cover bracket
- $125ono
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3085.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3086.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3087.JPG
Just Jap 3" Silicon Hose
- $10
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3084.JPG
Jai
0422925440
Edited by jaik
hey mate just wondering would you sell that rb25 bov flange? got the same bov n just need a flange...cheers
Hey mate how are you? do you know if these are a direct replacement for standard rotors on a s15?
cheers
edit: just saw ur first post... are they just a pair for fronts?
Edited by Pharonic
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
