my RB25DET is running like crap!!!!!
When it first comes on boost, it goes hard for a bit over a thousand rpm, then power just quickly fades. It's still boosting hard (according to the boost guage at 10psi), but good accelleration is just not there!!!. At high revs the engine is absolutly screaming its tits off, far louder than the noise the exhaust is making (only have 1 rear mufffler). Im getting beaten by soo many cars that i should be able to smoke!
Any ideas as to what the problem could be??
please help, this is so frustrating! im considering selling the car with the amount of trouble its given me!
https://www.sau.com.au/forums/topic/17922-help/
Have you got any aftermarket management? if not, you'll want to get some (like a SAFC) to lean out your a/f mixtures as the stock computer really messes with your power curve when the boost is turned up a bit above stock. Put your car on a dyno to see. I know mine was like that, and so are half the skylines on here.
https://www.sau.com.au/forums/topic/17922-help/#findComment-373626
Hi sumfatchin, R33 ECU's cut fuel and ignition when they see too much boost, your problem is a perfect example of what this feels like. Have you fitted anything to overcome the ECU over boost cut? Say a boost cut defeater?
https://www.sau.com.au/forums/topic/17922-help/#findComment-375480
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
    • Why would you not fit the biggest possible brakes?
