Hey everyone.
I had another thread in the suspension area about my car being defected for being too low. Well i went through regency yesterday and they didnt even check the eyebrow height measurement that i got defected for. lol.. just straight over the pits. Anyway the guy has written on my form
Re-instate eyelevel rear brake light
Re- instate 5 degree side indicators
Fix broken manifold stud
fix exhaust leak after cat converter.
Brake light is fair enough i think because i forgot that the spoiler was taken off when the car ws sprayed etc, easily fixed but the guy rekns that my car should have indicators in the front guards that must be visible from 5degrees at rear of car. My car is a r32 92 11th month. It doesnt even look like indicators were in there in the 1st place. No wiring for them etc. Just wanted to check if anyone knows if my car being the last of the 32's has to have these indicators installed ? My old 89 and my wifes 90 model havnt got them.
Oh and i asked the guy why has this been picked up now and not the other 4 times all up with the last owner the car has been through regency, and he said i have no idea.. lol.
So yeah anyone know if he's talking crap or not ?
Cheers
https://www.sau.com.au/forums/topic/179238-failed-1st-check-at-regecny/
hey i have a rear brake light that goes in the rear window ADR standards u can borrow!!
and i have a 93 r32 and i have side indicators!!
mine werent amber enough when i got defected lol
drop us a pm if u wanna borrow the light!
cheers
thanks for the offer dude. Iv got my old trx pinny rear brake light here im going to put in, it also sits in the rear window..
ok if your 93 has them then its a good indication that the inspector was correct and my car did have them..
cheers for your quick reply!
nah i believe that there stock front panels. Im thinking that if my car did have them b4 that they were removed and the holes welded over when the last owner had the car sprayed from black to how green
my brother got stick on indicators that just require a small hole to be drilled for the wire, theyr clear now amber though so dont know if theyll like that..
rad33... lol... defected for indicators not being amber enough... lol
worn globes... must be all the burnouts you were chucking with them right ? bit like how my tune up sticker could of caused a serious crash. lol
nah cars a gts t.. my old 89 wasa gts, didnt have them... my wifes isa 1990 4dr gts t and hasnt got them either
fyi, your car doesnt have indicators cos the compliancer didnt feel they were necessary. if you look at your normal front indicators, i believe r32s have a slight bulge or a lump to them. this can function as a side indicator by being visible from behind/5degrees. this was as designed by nissan and its really up to the inspector/compliancer to decide. im guessing if you look at two cars from different workshops they may even have different shaped lights cos the mechanics may have a differnt source for them.
anyway y not check to see if they comply your self. it shouldn't be too hard for you to stand next to your car and have a look.
  blackprincegts said:
<br />Hey everyone.<br /><br /> I had another thread in the suspension area about my car being defected for being too low. Well i went through regency yesterday and they didnt even check the eyebrow height measurement that i got defected for. lol.. just straight over the pits. Anyway the guy has written on my form<br /><br />Re-instate eyelevel rear brake light<br />Re- instate 5 degree side indicators<br />Fix broken manifold stud<br />fix exhaust leak after cat converter.<br /><br />Brake light is fair enough i think because i forgot that the spoiler was taken off when the car ws sprayed etc, easily fixed but the guy rekns that my car should have indicators in the front guards that must be visible from 5degrees at rear of car. My car is a r32 92 11th month. It doesnt even look like indicators were in there in the 1st place. No wiring for them etc. Just wanted to check if anyone knows if my car being the last of the 32's has to have these indicators installed ? My old 89 and my wifes 90 model havnt got them. <br /><br />Oh and i asked the guy why has this been picked up now and not the other 4 times all up with the last owner the car has been through regency, and he said i have no idea.. lol.<br /><br />So yeah anyone know if he's talking crap or not ? <br /><br />Cheers<br />
<br /><br /><br />
i have a 32 4dr that passed on thurs and i never had to install side indicators but they did look for them. i told the guy that they are in the front indicators. they have a seperate section and even have their own globe and he over looked it after that. mines an 89 tho.height was my biggest prob. had to hire suspension.
cheers 4 all the replies fellas.
I actually discussed the whole indicator thing with the regency inspector and said to him that in my eyes the buldge on the front indicator is visibl from 5 degrees however he said theres no 2 ways about it i need to install them. How do i argue with regency though, its stupid, they set down the rules and they dont even listen when you try to explain i find.
Cruizen33 : eyebrow height is from bottom lip of guard to centre of the wheel.. should be 360mm minimum on an r32, even though all the stock ones iv measured so far fall around the same as mine 357ish which is one of the things i was defected for in the 1st place.. In my case, regency didnt even check this, so in other words they didnt even bother checking what the cops originally defected me for. pfft,
as far as ive seen through regency 89-mid 90 32's dont have to have side indicators but anything after that must have them. The wernt direct from the factory so the place where the car was complienced should put them on.
  Deluxe said:
Do you have aftermarket front quarter panels?? Seems strange that it doesn't have them as it would have needed them to comply when imported!
My 89 R32 has no side indicators, but it's been in the country for a fair while.
hmmm interesting.. The compliance plate says Priority Porsch Imports.. Meh, i think im going to have to just bite the bullet and install the bastards..3rd week now of not being able to drive my car is getting very frustrating not to mention all the hardship it causes without my car. I just want it back on the road.
Cheers
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
