Great looking car. Would have rathered an r34 gtr, maybe after the lease on this one ends. No doubt it would feel better than a rex, by a lot, I doubt it. Its an 11sec car.
sorry but you cannot compare a wrx (even if it runs 11's) to a gtr, let alone a tommy kaira edition!
the wrx standard is already at its performance limits, by that i mean once u add i bit more power the clutch/gearbox/cv's etc simply cannot hold up!
the gtr on the other hand...well...i had close to 700hp in my r32 & it was strong!
40k technology v's 120-150k technology (chalk & cheese, sorry)
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3499809
  • Replies 51
Posted Images
:yes:
dont worry I luv the gtr much more than wrx's. By the way if you compare an sti or an evo to an r34, they do out perform the gtr in any situation that requires sharp turns and quick stop/start. Though if someone wanted huge power then the gtr is classes ahead.
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3500628
i agree with u - the smaller cars are manouvreable to a certain extend BUT gtr will always be king!
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3500754
whats his number? email it to [email protected]
Call the guy.... you never know mabye hes in a good mood... Good luck .. I had the pleasure of driving this Car On the Wisemens Cruise For a while.. , Out of all the 34's ive driven...I Have never driven such a Smooth 34....
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3501233
Very nice car. I have bought an R34GTT just recently and it is great but I will one day own a GTR but it is on the back burner till i get the money.
Awesome car indeed!!!
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3507215
  • 1 month later...
Thanks mate!!!
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3558283
  • 1 month later...
  • 2 months later...
I Dont blame Ya Sam , This is without a doubt one of the Best R34 GTR's And Also Most Rare In Australia ,
Hey Thanks Moei!!
Where u been, havent seen or heard u in a while.
The same can be said about u R34 GTR also.
Maybe we should try to hook our GTR's up and if we r lucky they might have babies together
That would look HOT!!! lol
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3822801
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
