hey guys just a quick question.
my cousin had a 96 R33 GTR with enough mods to get him putting out 350kw at all four wheels until he got rear ended at the light by some lady in a landcruiser.
my question is
he is certin that his rear end is of no use like tailshafts, diff etc but front end and gearbox is all still good.
if i were to transplant his motor into my R33 would i be able to hook up his front driving bits to my car basically transforming it into a GTR???
or it cant be done so just do the gearbox and engine transplant and leave it as a RWD car.
many thanks
Ash
https://www.sau.com.au/forums/topic/179292-r33-gtr-running-gear-in-r33-gtst/
no flaming here dude. good to get some feedbacks.
i understand having a heap of power for a RWD car wont be of use but ye reason for this conversion was id be getting it for a very very very very cheap price.
thanks all
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
