Hey All,
Got a friend who has been in a very unfortunate position of late. To cheer him up i have done (with No_respct's help) some mild pimping of his ride. Unfortunately despite my best efforts he is in love with his commodore, so that is the canvas on which i have been working. Despite his love for all things GMH he is a great guy!
I am looking for some 18 inch rims and tires with a budget of 1000-1200 for him. I was wondering if anybody had any idea about where i could try other than usuals such as Bob Jane, the quokka, trading post etc.
Anyone know someone who can hook me up for a good cause?
Thanks for your consideration!
https://www.sau.com.au/forums/topic/179294-need-rims-and-tyres-for-a-falcodore/
Check out Mr Mag in Morley. They have a fairly big range and I think they carry second hand rims there too. They also do tyres at pretty good prices.
If you like, you can have a look at the ones for sale in my sig... they're in your price range, but only 17's. It for a good cause, so I'll even do them at a lower cost for you if you like >_<
If you like, you can have a look at the ones for sale in my sig... they're in your price range, but only 17's. It for a good cause, so I'll even do them at a lower cost for you if you like :nyaanyaa:
Thanks for the offer!!!
Wish that i could solve both our problems and get your rims, the look pretty sweet. But i given that i am searching for old commodore bits they will not fit. Best of luck with the sale though dude! ;)
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
