yeah understand. I'II just replace and see what happens, as u can see its not all that bad however he has done a few other setups with the same hi-flow setup and it comes on a bit better..I think the power is about as good as its going to be with a hi-flow
  • Replies 41
Posted Images
youve got a spot on response - you cant get much better
more negative camber is required...adjustable arms is the go now..pitty I cant drive my car.
BTW...thumbs up to RE for the good result before! :nyaanyaa: They should be an SAU sponsor now yeah?? hehe
TD06 on an RB25 is awesomely responsive. I never got to go for a drive in it. But a friend raves about this setup . You only have to look at my bucket that is giving away 500cc and 0.5:1 compression to the RB25s to see how good a turbo the TD06-20G is.
Throw some more boost at the 3037 though and it will walk away from the other two setups
You have to remember that the RB20s run different gearboxes and diff ratios so the rpm vs power is different. But where it counts, road speed to power etc. You would think Bass Junky's car with cams and high flow on an RB25 woudl blow the RB20 with a laggy TD06 into the water...but results are very surprising.
So whose td06 is it anyway Paul? Funny thing is I was actually on the market for one (even contemplated getting yours Roy) but when this came up, and for the price I got it for, I couldn't refuse. When I saw the setup in person I was amazed, the turbo was almost brand new, it still had all the balancing marks on it and razor sharp edges.
As for the power, remember that it drops 1 psi across the rev range in that dyno, yes I know it doesn't sound like much but when you look at that on 14 psi it was making a shade under 255 rwkw, and then at 16 (trailing off to 15 in the higher revs) it jumps to 280rwkw.
Now to get the SAU VIC membership and start hitting the track!
khunjeng that result is by far the most impressive for a high flow I’ve ever seen! What brand is it? I’ve only ever seen two high flows perform that well, one was a GCG owned by a guy on here, umm I think his name was devilfish or something with fish in it, and I once saw a massive AVO high flow do that.
Bring on the forged engine!!! (and ensuing poverty)
I think i know whose it is :thumbsup:
Go the mid range of the RB20 :ph34r:
Up until Paul noticing the other day. I had been keeping it pretty quiet that my thing made way more power, way sooner then many of the RB25s out there making the same power. No doubt has to do with the gearing that my road speed means slightly higher rpm...but still, for a std RB20 with a turbo slapped onto it....it punches pretty damn hard :rolleyes:
thats pretty impressive...explains why I see you car (on the occasion) and it looks like its flying
My Highflow...dont like to advertise it, its been developed by my tuner and a turbo joint. I'm a happy with its performance, cam gears got it going.
However yours on 15-16psi and ur making some nice power...looks pretty good to me
I up the boost and the thing near kills me. I wind the boost down to about 230 odd and the thing is entertaining to drive. Its a real shame i didnt have the camera in the car at last years Dutton/Sandown when i ran 1.5bar. The thign was very hairy to drive...good thing it was only for 1 lap :rolleyes: No way i woudl drive PI etc at full boost until i get new suspension
Mate, I've gotta hand it to you, that is by far the most impressive curve for an rb20 I have EVER seen, and by no means is a td06 a small turbo. I have never actually heard the full specs of your engine, does it run cams, who tunes it? Have you run it down the 1/4 on that boost? Geese I'm speechless, i have a mate with a td06s on a 25, and his got a very similar curves to that
I up the boost and the thing near kills me. I wind the boost down to about 230 odd and the thing is entertaining to drive. Its a real shame i didnt have the camera in the car at last years Dutton/Sandown when i ran 1.5bar. The thign was very hairy to drive...good thing it was only for 1 lap :thumbsup: No way i woudl drive PI etc at full boost until i get new suspension
I feel ya troy. When I run mine on 1.3bar max torque hits at about 4500 and is violent! heheh Yours would be quite exciting.
Hey Paul, thanks for that comparison, its nice to actually have a solid evidence of my progress. As for traction, through 1st its non existant, 2nd it hooks up at about 5 grand and just takes off from there. Admittedly, my suspension is set up for drift with stiff zeal coilovers all round (cant remember the rates off the top of my head). The best thing about all of this is the satisfaction I get from driveing something I built.
Milan: The car didnt even hit knock levels at 16psi which is all it ever sees now that I've sorted the boost control and it carries nice afrs throughout the rev range. On here its a pretty normal occurance to see rb25s running 300rwkw throughthe likes of gt30/40's and 35/40's on stock internals. But I still dont like running it internally stock, hence why I'll be getting an engine built within the coming months and then aiming for spot on 300rwkw (around 20 psi should see me there). Im just thinking to stick with the 25, or go 25/30 and a bigger exhaust housing, any suggestions?
Hmm that sounds about right, you really done your home work. In my case i didnt really know much about cars so i would be doing it the old fashioned way, trial and error :thumbsup:. I had my stock t28 boosted to 15 and i was making 201.8kw at the wheels, i drove the car around the corner and my clutch went.... so im guessing you must have changed that hehe
I cant really say much on what you are planning to do because none that i know has done those sort of conversions, as in 25/30, but it does sound interesting. Im guessing it will cost you a bit more to do, but i reckon just stick with the 25, i mean hell there will be a very very few people that can beat you on the roads....
Hell in my car i only lost to this red sylivia thats in dandenong.... aperently its a ca18 but he cleaned me off....
still its nice to see that somebody takes their time and does things correctly and gets positive results, cheers
Its a completely std RB20 with cam gears tuned by Racepace on Shell 100. I ran it at the drags with 14psi on old bald RE55s for a 12.9 @113mph with a 2.25sec 60ft time. I dont have the heart to launch it hard because of the std gearbox. I would hope i could improve on the 12.9 now that i have a diff, wind some more boost in with the comfort of having an RB25 box to go in. But who knows, maybe 12.9 will be as quick as it ever runs ?!?!?!
So I'm guessing that boost was when you cranked it up to 21 psi then? Do you have a copy of you 14 psi run? I would be interested to see how the midrange behaved when the boost was turned up. A 12 secound pass is by no means slow for an rb20.
On a totally different note, do you have many problems with you highmount setup and the screamer on the street? I originally wanted 2 go stealth lowmount, but like I said, when this package came along it was too good to refuse. Also, how is your Greddy manifold holding up? When I was having a chat to the guys at Rank Rotary the other day they said that because its such thin stainless it wouldn't last long, have you had any issues?
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
    • looking forward to your t56 swap man its a game changer if it works!
