Hi people
Cant find out what globe type this is?
See the pic
Some people say its h3, h3c, h1, h1 with a h4 connector.. Ive had mix answers.
My car is a 1992 R32 (HCR32) Type-M RB20DET 5spd manual. The headlights are the new projector shape ones, not the old n1 (89) ones.
Could someone please clarify this once and for all, as im trying to purchase HID kit and have no clue which path to go down.
https://www.sau.com.au/forums/topic/179309-what-globe-type-is-this/
the base of the globe? where the 3 pins are at the bottom? cause there is nothing there. i don't see any print at all anywhere.
does the actual globe come off the adapter part? because I have to replace this part, my light doesn't work the filament is loose inside and busted, ..
so when you buy it do you buy the actual whole piece I posted the picture of? or do you just buy the globe to suit it and replace it (if it comes apart?)
well I need to replace this globe tomorrow. and my H1 HID kit arrives next week
so would there need to be any modification to the H1 HID kit or will it be pretty straight forward to install, plug n play?...
sounds like there could be some difficulties as you said 'h1 bulb in a holder'.?
I have to agree with MANWHORE. I've purchased a set of hids and the visibility is much better than what my original headlights were doing, but there is a lot of glare compared to what retrofits can do. If your set is already on its way, I just hope you chose 4300k globes to come with it. I found that 6000k was too blue and ricey. Only my opinion.
I wouldn't say they're a complete waste of money though. The kit did what it was supposed to do (give a better light output), but it's not good for on coming drivers.
Up to you mate.
Thanks for the info
I am still considering whether to get 4300K or 6000K, but 4300K may be the way to go
At the moment my halogen stock bulbs are so crap that oncoming cars to me, I can barely see the road.. it feels like my lights arn't even on half the time.
Would the H1 HID kit fit, or would it need some sort of modifications?
I know what you mean mate. I remember driving my car with the standard lights and it was shocking. Couldn't see a thing. Driving at night while it's raining was the worst.
The kit I had was pretty much plug and play.
Hi people, i also own a R32 Gtst and was looking into getting a hid kit. just wondering that one of you guys quoted that the 6000k was blurry but wouldnt the 4300k be to bright for oncoming car? also would the 4300k look just white? cause i want the blue tinge so what kit should i get?
Go for a custom HID fit, Ronin here has done one
I fully agree with everythin MANWHORE says
I'm doing one at the moment, using twin FX45 bi-xenons, I'm just trying to work out fitment issues and a shroud
Then trying to make a clear headlight cover out of perspex, because my current one is the glass crapper with the lines through it
Do a search on "HID conversion" on the search button you'll find it.
If you do go for the HID kit, you'll notice how crap it is, especially in the factory nissan projector lense, it'll focus the light all in one spot and scatter the rest
All the hid kits are the same. They'll all give 'blurry' light. The 6000K globes are more of a blue light and the 4300K is supposed to be the colour of sun light. If I were to get an hid kit again, I would go for the 4300k. I wanted a blue to my light, but I found 6000K too much.
If I were to upgrade to better lights in the future, I would definately go retrofitting. I kind of regret buying my hid kit. It's an improvement, but.... it's up to you.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
