Hi all this is my situation.
I have a 96 r33 gtst and when driving and coming to a stop and sometimes whilst driving the car will stall.
Whilst sitting at the light after stopping the idle of the car sometimes sits at 1k or 1.2k or even sometimes
after i have started it again it idles at 2k. If i rev it it drops back to normal 700rpm. Im thinking it may be the AFM.
My car has the following mods: cat back exhaust, bov, boost controller, pod filter. Any feedback would be greatly appreciated.
Price for a new airflow meter if that is the problem?
regards
jim
https://www.sau.com.au/forums/topic/179316-r33-gtst-staling-problem/
so most probably it has a leak right? or if i can tighten it it will take more pressure to open up.
just a quick question how does the bov controll the idle and stalling. vaccum leaks i guess
No, it wont have a leak. Its just ATMO venting.
The AFM (near your pod) normally has the air re-circ back to it. The ECU expects it to be there and buy installing a pointless Atmo BOV, your sending the ECU into a fit.
To fix the problem for good you have two options.
1. Put the stock BOV back on (less than $100)
2. Purchase some management, pay for a tune (potentially over $1500)
BOV's are a pointless mod, much like pod filters. They offer not performance gain over the OEM gear, if anything they hinder performance
a bandaid fix for it is to get new spark plugs.
spark plugs?? i had the same problem the factory bov (when run in atmo)is held open a little by vaccum from the manifold which basically intoduces a leak into the intake system, the engine is taking in unmetered air, if it is adjustable just tighten it a little other wise vent it back and you shouldnt have a problem.
Edited by drf76
spark plugs?? i had the same problem the factory bov is held open a little by vaccum from the manifold which basically intoduces a leak into the intake system, the engine is taking in unmetered air, if it is adjustable just tighten it a little other wise vent it back and you shouldnt have a problem.
If it were a factory BOV you wouldn't have aproblem if it were open at idle for letting in unmetered air, as it'd just be allowing the same metered air to travel a different path INTO the engine.
i always thought that it would cancel out due to the air being sucked into the turbo and air being blow out towards the throttle body pipe where the bov is mounted, taking of the bov recirc pipe stuffs the balance and causes air to be drawn in, its just like having a pcv valve connected with a catch tank that is vented, it would cause a vac leak through the rocker cover, thats why near the bov recirc pipe you have the breather for the rocker cover into the intake pipe (near the afmeter) to stop a vac leak to the manifold.
Turbo does nothing at idle.
Air comes in through AFM, through turbo, through throttle, into manifold.
If BOV is open
Air comes through AFM, through turbo (And also through the recirc pipe and comes out just before the throttle) and then into manifold.
Whilst the car is in vacuum. Air is being SUCKED not forced through the intake.
If BOV is open
i know air is not forced into the intake lol wrong wording, its not on boost at idle, the suction before and after the turbo cancels out when you have the recircirc pipe connected so no air is being drawn through the bov, put it this way would it be good to have a small hole in the intercooler piping which is wat the bov is basically doing.
If there's a recirc ppipe, then that's like saying, with a hole in the intercooler piping, put an AFM so the ECU knows.
The air, even if the engine is pulling air through the BOV from the recirc pipe, the recirc pipe is still AFTER the AFM, therefore, it's affectively just "changing lanes" but it still went through the toll
no its only there on idle due to the high vacumm, so its sealed under boost, im just saying at idle low rpm with vacumm. Its too hard to explain, its exacltly the same a have a pcv valve with a vented catch tank almost the same thing. By the way Im basing this if the factory bov is run to the atmoshpere, i understand that if it run with a recirc pipe there is no difference it just taking a different path still to the throttle body, i think there was a misunderstanding MBS206
Edited by drf76
If there's no recirc pipe, that's most likely one of the huge issues.
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
