Team Cowie - 12.474 seconds!!
At TOTB we broke the 4wd 0-300kph time held by Veilside Japan there time was 13s and we set a new record going from 0-300 kph in 12.474sec.
I took it all the way to over 200mph here is some of the data taken from the timing gear.
0-30 1.226
0-60 2.539
0-100 4.346
0-150 8.085
0-200 14.751
Some photos just before we took the Veilside 0-300 record.
https://www.sau.com.au/forums/topic/179320-new-0-300kph-4wd-record/
ummm didnt the veilside car do it on nittos?
You've got to be kidding me?!?!?
This is an OUTRIGHT record. How can it be any clearer than that?!?! Besides, slicks do VERY little to improve how fast you can reach a particular terminal speed.
So the fact that the Heat Treatments GTR reached 300kph in under 7.6s isn't taken as a record because it wasn't targetting 0-300kph?
Very nice good to see the old R32s still getting publicity :thanks:
so fastest 1/4 mile street and drag, fastest 0-300 oh yeah :)
For the dude above, the Veilside car was an R34, did it over here in NZ, just below Taupo, think the same year a Porsche crashed spectacularly on the same circuit :)
GTR:
Couldn't find the porsche crash though :down:
yeh the one im talking about was the grey R32, 13.72 was the time beer baron, dont think it was on slicks when it did it and had a strange miss-fire halfway through second.
and i think slicks would make a differnce as to how quick you reach a certain speed, 0-300 is a timed event, slicks = less time wheel spinning, and more time on the power, means you get to that speed in less time. unless you want to get into maths/physics with rolling resistance at higher speed etc, i really cant see how it wouldnt make a difference
i know you like your drag racing, go run on a set of $30 retreads vs some real good tyres. 0-300 is basically the same format as drag racing, just with a different goal
Edited by VB-
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
