Just wanted to let everyone know, I've just had cruise control installed by nigel from www.cruisecontrol.com.au
$800 installed and it works great - and hopefully will keep my licence intact :nyaanyaa:
stalk looks like this (set, resume, accel, decel, and 2 memory speeds (eg 110 and 60).
sorry out of focus
control unit and throttle looks like this
control unit hidden behind ABS
https://www.sau.com.au/forums/topic/179321-cruise-control/
This looks great, i will have to get one.
Whats the minimum speed set? My sisters only goes down to 60, but 40+ would be good cause school zones are painful.
And what is the maximum? again mysisters is gay and wont let you set it higher than 109km/h which is gay for highway as i like to do about 115.
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-3268086
the stork looks awfully low down isn't it a bit close to ure nee?
i was looking at getting cruise put in also but i don't really want another stork can you get buttons on the dash in stead or somthing else?
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-3271737
I hate the stalk ones - the rostra ones I have use a rf linked control (so no wires) and clip onto the steering wheel. You can even unclip it and hand it to the wife in the passenger seat and she can make the car go faster or slower until she is happy.. :-)
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-3271922
  • 3 years later...
http://www.skylinesaustralia.com/forums/Sh...nt-t339098.html
in reply to this thread:
DO NOT DIY IT! if you get the linkage wrong you can jam the throttle. not the most ideal thing with you stand on the brake and the car WILL NOT slow. pay someone.
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-5487987
clutch in? engine off clutch out, brake => all good
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-5489658
had a reply back from the guy on ebay
Hi Tom,
The unit is fully electronic OE unit (Delco). It uses a magnet on the tail shaft to measure the speed and controls the throttle from the unit.
It will suit a turbo motor as there are no vacuum connections required.
You need to connect the control cable to the throttle (universal brackets are supplied).
should be about $200 which sounds more reasonable to be (especially being a uni student and all) and should be a case of plugging a few things together and away you go :)
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-5493565
i have aftermarket cruise on my s2 stag and its awesome
i looked into the magnet ones and the big problem is when the magnets come off and finding replacements, the awful panel, and getting a good spot to attach the kit. Plus i found that after so many revolutions the cruise will not opperate so it has in effect a speed limitation.
highly recommend getting one with a stepper motor instead of an extended reservoir vac tank also.
mine is a little slow to rect on hills etc although turning up the gain will help but CBF
covered 3000kms towing in 2.5 days and the cruise was awesome
when installing it i went for a stalk in the end although i already had a cm21 (for ap models) steering wheel remote CBF attaching it and went lazy stalk
why go magnet when the stock ecu has a speed wire to tap into?- this way it never runs out of scope likethe magnetic ones do.
if you are looking for a cheap option i will off load the cm21 for $50 (cost $140) as its useless to me and it has never been used! (a little sly selling stuff here...) - just need to buy the stepper motor then and tap into the loom.
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-5494402
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
