Just wanted to let everyone know, I've just had cruise control installed by nigel from www.cruisecontrol.com.au
$800 installed and it works great - and hopefully will keep my licence intact :nyaanyaa:
stalk looks like this (set, resume, accel, decel, and 2 memory speeds (eg 110 and 60).
sorry out of focus
control unit and throttle looks like this
control unit hidden behind ABS
https://www.sau.com.au/forums/topic/179321-cruise-control/
This looks great, i will have to get one.
Whats the minimum speed set? My sisters only goes down to 60, but 40+ would be good cause school zones are painful.
And what is the maximum? again mysisters is gay and wont let you set it higher than 109km/h which is gay for highway as i like to do about 115.
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-3268086
the stork looks awfully low down isn't it a bit close to ure nee?
i was looking at getting cruise put in also but i don't really want another stork can you get buttons on the dash in stead or somthing else?
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-3271737
I hate the stalk ones - the rostra ones I have use a rf linked control (so no wires) and clip onto the steering wheel. You can even unclip it and hand it to the wife in the passenger seat and she can make the car go faster or slower until she is happy.. :-)
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-3271922
  • 3 years later...
http://www.skylinesaustralia.com/forums/Sh...nt-t339098.html
in reply to this thread:
DO NOT DIY IT! if you get the linkage wrong you can jam the throttle. not the most ideal thing with you stand on the brake and the car WILL NOT slow. pay someone.
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-5487987
clutch in? engine off clutch out, brake => all good
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-5489658
had a reply back from the guy on ebay
Hi Tom,
The unit is fully electronic OE unit (Delco). It uses a magnet on the tail shaft to measure the speed and controls the throttle from the unit.
It will suit a turbo motor as there are no vacuum connections required.
You need to connect the control cable to the throttle (universal brackets are supplied).
should be about $200 which sounds more reasonable to be (especially being a uni student and all) and should be a case of plugging a few things together and away you go :)
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-5493565
i have aftermarket cruise on my s2 stag and its awesome
i looked into the magnet ones and the big problem is when the magnets come off and finding replacements, the awful panel, and getting a good spot to attach the kit. Plus i found that after so many revolutions the cruise will not opperate so it has in effect a speed limitation.
highly recommend getting one with a stepper motor instead of an extended reservoir vac tank also.
mine is a little slow to rect on hills etc although turning up the gain will help but CBF
covered 3000kms towing in 2.5 days and the cruise was awesome
when installing it i went for a stalk in the end although i already had a cm21 (for ap models) steering wheel remote CBF attaching it and went lazy stalk
why go magnet when the stock ecu has a speed wire to tap into?- this way it never runs out of scope likethe magnetic ones do.
if you are looking for a cheap option i will off load the cm21 for $50 (cost $140) as its useless to me and it has never been used! (a little sly selling stuff here...) - just need to buy the stepper motor then and tap into the loom.
https://www.sau.com.au/forums/topic/179321-cruise-control/#findComment-5494402
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
