Im in the process of rebuilding my neo rd25. This process started 14mnths ago and i have since changed my dam mind about 100 times. I was orignally going to run a hks gt28 kit ( for sale ). But if im forking out some much for a reliable big power engine then might as well match a turbo to suit. I need some advice and suggestion on running a package that is both reliable and effective. My power goal is 450rwkw..Yes i know its going to be a lag monster....But im a power junkie....We are strictly taking about engnie mods only and not susp driveline etc which I am fully aware is also a priority!
Engine mods:
tomie in tank lift pump
x2 bosch 044 pumps
sard fpr
surge tank
sard 1000cc injectors
HKS gtr hks fuel rail
tomei poncams 260
hks timing belt
heavy duty valve springs/retainers
k-line valve guides
hks 1.2mm gasket
head work
head studs
wiseco 40thou pistons
head decked to suitable comp ( thinking 8.8)
eagle h beam rods/bolts
acl engine bearings
main stud kit
balanced bottom end
crank collar
n1 water/oil pump
to4z .81 a/r
6boost manifold
hybrid cooler
x2 z32 afm
power fc/av-cr
splitfires
greddy plenum
q45 tb
It will only be a weekend driver and never see track days.
1. I dont know weather to sell the n1 oil pump and fork out the jun one together with a larger sump? Would this be needed? I will modify whats needed to the cylinder head and try keep oil down bottom end.
2.How is the power fc going to run the twin afms?
3. Splitfires sufficent or do i need some mw ignition
4. how about cam gears? I heard NEO dont respond to them and waste of money
5. Will there be any clearance issues mounting the turbo?
any feedback appreciated
Edited by ovabooster
https://www.sau.com.au/forums/topic/179325-rb25det-rebuild/
whats the point of having an 450rwkw weekend driver?
was the manifold meant for a r33? if so you might have clearance issues with the turbo.
Edited by BaysideBlue
https://www.sau.com.au/forums/topic/179325-rb25det-rebuild/#findComment-3268174
1. Never see's track days - N1 should be fine. If you were going to flog it i would personally get a JUN for that application.
2. Fine
3. Yep, you might need an ignition box (HKS)
4. In stock for the NEO doesnt like them, but your no longer stock/ish so give em a whirl
5. As you said, manifold is custom made... so mute point that
https://www.sau.com.au/forums/topic/179325-rb25det-rebuild/#findComment-3268195
it should be noted if you plan on using the neo 25 powerfc it will not support twin afms
your options are;
use neo 25 with safc II or neo to split the afm signals and math squish them to a single afm input ECU
use rb26 powerfc and run twin afms correctly - but youll need to get it working with all of the neo sensors etc
https://www.sau.com.au/forums/topic/179325-rb25det-rebuild/#findComment-3268199
Most of the mods sound good, however i would get oversize valves to go with the headwork, and bigger cams. no need for 1000cc injectors, just 720's or 800's.I would only use a thicker headgasket if it is necessary to achieve the correct squish/compression. Have you considered putting an rb30 bottom end in, as it will probably end up cheaper(as you can sell your existing bottom end for more than an rb30 bottom end will cost), and it will reduce the lag cosiderably making it a heaps nicer drive.
https://www.sau.com.au/forums/topic/179325-rb25det-rebuild/#findComment-3268341
most of the parts are already purchased....As mentioned the whole package was orignally built for my hks gt2835. I've gone alittle over board since then. I already have a power fc so what are my options?....sell it and get a wolf 3d? I wouldnt have to spend to much more I surpose coz i can flog off the z32 afm too..It just a matter of selling things at the right price. I also already have the 1.2mm head gasket. Runing 40thou pistions on stock thickness gives comp in the low 8's, I think 8.3...thinking better to get the engine builder to deck the head to a suitable ratio instead. I also already got nismo 480cc injectors....so upgrade to sard 800 is the go. Cams are also purchased and i read good things about these 260's.....Would oversize valves not benefit much with these as I think bigger cams would better. I have considered a rb30 bottom end..trust me and only if i thought of that at the start...but the i would have to sell most of my gear...to much hassel. I might just get a spare smaller a/r for driving and larger one for dyno's or when i need to boost my ego alittle....
If any1 is interested of know's of any1 else who is
For sale
Brand new nismo 480cc injectors
Brand new Power fc
Brand new z32 afm
Brand new hks gt2835 pro s kit
pm for prices
https://www.sau.com.au/forums/topic/179325-rb25det-rebuild/#findComment-3269230
