I have a GReddy Oil Cooler kit located BEHIND my Intercooler and in front of my radiator.
Was wondering if it would perform better if i moved it to the side of the bar (it has vents and can get all the ait it needs)
Was speaking to someone at a reputable workshop and they advised that most cars run it behind the intercoolers in the middle as the sides have disrupted air? <-- don't really know what that means but i take it that it doesn't recieve nice flowing air.
So who has their oil coolers on the side or has had them there?
Any temp differences?
If it makes any sense, i have a R34 GTT with a Nismo front bar.
Cheers
Edited by Fujiwara
https://www.sau.com.au/forums/topic/179349-oil-cooler-location/
Anywhere where it will get maximum airflow without hindering the performance (heating up) of any other cooling device (intercooler, radiator etc.)
If you put it out of the way of the intercooler but in the way of the radiator that would be the best spot without any major modifications imho.
Radiator should be able to cope, if it does cause an issue main way to cool your engine (i have found) isnt additional capacity in the radiator, its raising your bonnet at the back and venting at the back, works like a charm.
Edited by hecticrb25
Hey Dude,
I have just fitted mine to the side.. inside wheel well,i wouldnt put in front of a radiator as although you will be taking heat away from the oil you'll be adding some back into the waer via the radiator.The best position is away from the intercooler and radiator, you can hard mount it when the hoses are long, easiest way for fitment is by removing the headlight and front bar on a R33 it may be the for a 34, good luck with it. cheers
of thats just great...
i can't do this myself cauz i;'ve never taken these things apart.
Nor can i fabricate brackets/mounts to fit on the site.
Have to see what some performance shops will charge me >_<
No doubt an arm and leg
Nows the best time to start! Its just bumpers, some brackets, inner guard liner etc. Get stuck into it, just stick it all back together
Prolly your family's arms and legs as well. Its the labor that kills you. Search this forum for some guides and inspiration. Might not be as hard as you think. Its just large scale Meccano :D
the side duct is the BEST place to put it. you will need to make a vent in the rear of the guard liner though for the air to escape, but once done you now have a much better set-up.
I'd like to mount my oil cooler kit where the stock intercooler used to be and perhaps fabricate an air guide to it. I drive an R34 and will probably do it myself. If i get it done prior to you, I will try to put together a guide.
Edit: On second thoughts, check http://www.skylinesaustralia.com/forums/in...p;hl=oil+cooler
Good guide for an R33 and should translate to R34. Great location too.
before you even bother changing anything, are you actually having any oil temperature related problems ?? i would take a guess that although its not in the most ideal position, it will still be effective enough where it is.
its not a case of finding the best location gives you more power (like a fmic), but rather its purpose is to just regulate oil temps and keep them under control. if its doing that job already, then there isnt any need to move it.
^^ pricelessly, you'll prolly find the position between i.cooler and radiator is fine.
Hmm...
no problems with cooling or oil temps.
Just thought i'd move it to save trouble later on if it does occur.
But maybe you're right.
I'll keep it there and move it if i have to.
Thanks for the advice guys!
My favourite spot is to have it on the side. There is room on r32s and r33s to run the lines underneath the headlight and put it on the right hand side.
I prefer this, because it has its own dedicated airflow. Also, its neater, because you don't have to run the oil lines either over or under the radiator (messy)
  • 11 months later...
Just a heads up. I fitted a greddy oil cooler and relocator kit to a r32 gtr. Oil cooler between the ac condenser and intercooler. It's a bitch of a job to do. Will never do it again !.
Has anyone else got this set up ?
Have you taken your car to the track and did it keep your oil temperatures down ?
Cos if this setup can't take a track outing once in a while I will not be happy in relocating the mother
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
    • The only way to make that better is to weld on some bozozoku tips up past window height and roll with the cool kids.
    • I'd want an even MORE side on view. More or less you want to make sure the outlet is actually square with the outermost part of the bumper. Or you end up getting soot all over your bumper from your hektik exhaust. In any case, it looks pretty close. I think the way to fix this is probably more of an overhaul at an exhaust specialty shop if you want tips that are rounded off or sit nicely with the bumper but have proper clearance and don't move - Probably more of a redesign than a quick fix. I've pencilled in my own exhaust with its own various problems, pinholes, PITA fitment, and other issues and can see myself going to a shop and saying "JUST DO THIS BUT BETTER?"  Which is gonna work better than any more small fixes. I'm gonna chime in here officially with "from an outsider perspective this exhaust looks fine so this is self OCD probably" (which I also suffer from)
